Hi guys,
On the r33 climate control, when you turn the lights on, the display dims.
Thinking about it, this could be due to
1) circuit connected in series so display is experiencing a voltage drop because all the other lights are being powered
2) It deliberately dims, thus it must have a connection which tells it the lights are on
Does anybody know anything about this? Or how it works?
I want to keep it bright, even when the lights are on. If the reason is 2, then that should be an easy fix, if its 1, gonna be difficult
Thanks!
https://www.sau.com.au/forums/topic/384411-r33-climate-control/
I have done this after I added a blue film to the display.
There is a wire that completes a circuit when the parkers are turned on.
I removed it from the connector block that plugs into the climate control unit.
The unit no longer dims when the lights are turned on.
ah fair enough
I need to do that to mine, I always thought it was brighter with the blue perspex. I guess it depends what tint you get
If you have a test light or multimeter handy should be easy to find the right wire. pull the plug out of the back of the climate control unit and test each wire with the light switch on and off.
If you dont have a multimeter then find one :P
Or maybe someone on here knows the answer/can test for you
Unplug climate control plug, put negative terminal of multimeter to chassis ground, probe the wires in the plug whlie turning the lights on and off
If you find a wire that has no power with lights off and power with lights on then that's your wire
thanks man
  • 4 months later...
Just a note to anyone that tries this.
Taking the wire out does indeed stop it from dimming, it was a red wire with a blue stripe on mine.
However, this wire also lights up the climate control buttons when you switch the lights on. Taking it out means no lights for your buttons.
Id changed the climate control button lights to blue too so was a bit lame not having them. Rectified this by making my own wiring loom that comes from the wire that i pulled out, and goes directly to the lights for the buttons. It was easy because the lights themselves are easy to access.
So now when i turn the lights on, the buttons light up, and the display doesnt dim :D
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
