Driving Sports
Twilight Drift Season Final
Thursday 22nd December, EC 9am till 5 pm
YES ITS A DAY EVENT WITH NEW CORNERS ON THE MAIN TRACK!!
MAIN TRACK (North Circuit, dry), Entry fee non members $300 + CAMS $57 , full members $260
Drift from Turn 2 , 3 the new link road turn 4 into 9 then turn 10,11,12
No drift on turn 1 and the main straight
SKID PAN (wet)
Entry fee $190 + CAMS $57 non members,$ 150 full members
FIGURE 8 / PEANUT (dry)
Entry fee $190 + CAMS $57 non members ,$150 full members
You can chop and change between the wet pan and figure 8 when you like
main track entrants can also hit the figure 8 while waiting for their session
PASSENGERS in cars without a cage on the wet skid pan is ok.
Minimum cams approved half cage for passengers on the figure 8 and main track
Entries will be capped, 60 for the main track, wet pan 38, fig 8 22
SO BOOK NOW
Do not wait till the last minute pre paid entries will only be accepted up to Friday the 16th of December
send a deposit now and lock in your spot before we are full.
Entrants for on track activities will receive one pit crew pass and one pit/ paddock car pass
The first 40 main track entries receive free pit garage
FUSION CAR AUDIO
SOUND OFF Entry Fee =$ 30
SHOW n SHINE Entry fee =$ 20
On track activities start at 9 am and end at 5 pm
Sign in and Scrutineering. For entrants will open at 7:30am at gate 7
drivers briefing 8:30 am. DO NOT BE LATE.
A 1 kg CAMS approved Fire Extinguisher is recommended
Heaps of action for drivers and spectators - 3 different dedicated drift areas, DJ in the pits, sound off show n shine, give a ways/prizes, hire a drift car + more
SPECTATORS entry is $20, kids under 14 FREE
Further details to come on the day schedule; give a ways/prizes and more
If you have something on the 22nd Dec do whatever must be done to cancel it and GET to this event
you don't want to miss this one!
To book fill this entrant form http://www.drivingsports.com.au/entrant-form.html
Need more info email us [email protected]
Let's slide out of 2011!!
Edited by KLR33
ONE WEEK TO GO!!
The Twilight Drift 2011 Season Final is almost here, this DAY will be the most drift we can pack into Eastern Creek in one day!!
As well as non stop drift ,there will also be loads of off track action with more GIVEAWAYS then ever... here's just a few......
Etnies will be giving ALL DRIVING ENTRANTS a limited edition Etnies / Driving Sports shirt
PLUS, 10 shirts for lucky people in the crowd
http://www.quattrosports.com.au/Etnies.aspx
Charlestone Performance Center will be giving away a 3 inch varex remote control muffler
http://www.charlestone-exhaust.com.au
Ksports Australia will be giving away their new hydro hand brake
http://www.ksport.com.au/
GCG turbos have kindly donated 10 gift bags with a shirt and plenty of other cool stuff inside
http://gcg.com.au/index.php?option=com_content&view=frontpage&Itemid=1
Focused Solutions North Wyong will be giving away 40 liters of Power plus e85 blend for 2 guys running e85 on the day
http://www.powerplusfuel.com.au/racing-fuels.php
There will be a TIRE CHANGER there on the day to strip n fit your tires, just $10per tire
Buy & fit New tires 235/ 45 / 17 for $90 each, if you want other sizes please contact us asap
Also head to our facebook page to enter our PASSENGER RIDE & SPECTATOR PASS COMP!!
+ more giveaways and updates to come - stay tuned & spread the word!!
see you there
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
