righto fellow automobile owners haha
bout to put new brake lines on the 32 and gonna be flushing the system with all new fluid,
wats the best fluids to use for street and track use and wats working for people out there!!!
i've been searching the forum up and down and cant find a conclusive answer so all responses are going to be a help
cheers blocka
https://www.sau.com.au/forums/topic/384520-brake-fluids/
Im not an expert mate but am lead to believe a dot5 fluid is the best as it can handle more heat before boiling brand wise unsure whats best but id imagine any dot 4 or 5 fluid would be up to the job. Ask few of your local brake specialists see what they recommend mate :)
https://www.sau.com.au/forums/topic/384520-brake-fluids/#findComment-6133961
I've been running the motul RBF 600 for street & track without an issue. Except its all street at the moment.
Just remember to flush correctly when changing fluids, this is a DOT 4.x I believe
EDIT: I'm not sure if your supposed to do this or not...the motul I bought is from a bike shop
https://www.sau.com.au/forums/topic/384520-brake-fluids/#findComment-6133999
Dot 5 is silicon based and cant be used. Use dot 4 or 5.1. I used to use the Motul 600, but i'm now using the Nulon "super dot 4 extreme performance". Its rated to 280 degrees (so not as high as the motul, which is rated to 310) but its less than half the price and you can get it anywhere.
https://www.sau.com.au/forums/topic/384520-brake-fluids/#findComment-6134080
someone was selling bottles of motul in classifieds here for 25$...or u can get it at autobahn for 40$
I used it, even though its expensive i figured how often do u really change brake fluid anyway.. I bought 2 bottles but I still have 1 left, 500ml should fill your whole system...
https://www.sau.com.au/forums/topic/384520-brake-fluids/#findComment-6134292
motul 600 or the 660 i found it works the best at extreme temps,i tried alot of them over the years,just make sure u dont mix the motul stuff with any other brake fluids so replace the whole lot u will need 2 x 500ml bottles
https://www.sau.com.au/forums/topic/384520-brake-fluids/#findComment-6135437
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
