hey all.
im parting my car, as i CBF waiting for it to sell.
so here goes..
shell - $4500
1993 mspec, Clean rego;d shell, sunroof, gtr front guards, geniune N1 gtr front bar, gtr front indicators, BRAND NEW BC coilovers, rear camber arms, front caster arms, hicas lock bar, vanquish roof spoiler, origin s13 boot lip, CF vented bonnet, bolt on rear guards, r34 gtt front brakes with slotted rotors.
NO rear seats, no drivers seat, no diff, no engine, no gearbox, no wheels.
can make cheaper for removal of parts.
engine built rb25 - $6000
s2 RB25, RB25 gearbox with excedy heavy duty brass button clutch
Mahle forged pistons
spool rods
crank was balanced, grub screwed
block decked, honed, acid dipped
block grout filled
nitto oil pump
ross metal jacket balancer
n1 water pump
oil restricters
head to sump oil drain
refreshed head
gtr valve springs
tomei pon cams
r34 neo CAS
r32 gtr rocker covers/timing cover
mines cam cover baffles
working vct
gates timing belt
has done about 1500kms worth of use.
made 350.1rwkw at horsepower in a box on e85.
RB25 gearbox + clutch - $1400
excedy heavy duty button clutch
VSKF - $3000
18x9-6 and 18x10.5 -5
225/40 and 235/40 neutons
black with chrome dish
fuel setup - $500
external pump, surge tank, magnaflow fuel filter, speedflow fittings for pump surgetank and filter
gt3076 .82 + full lines - $1600
surge slotted gt30, .82 exhaust, speeflow fittings and braided lines
1500kms use max.
helps highmount mani - $850
50mm gate port.
Plazmaman intake plenum - $900
rb25 throttle body inc, all fittings and bottom half of plenum also
id1000cc with rail, aeromotive FPR, lines + speedlow fittings - $1200
z32 + plug $200
defi BF gauges x3 - $800
oil temp, oil pressure, water temp, control unit, light up white with black background
bride style seat with superlow rail - $450
takata style harness - $150
tail shaft suit rb25 in r32 - $200
made by hardie spicer
power fc + hc - $1400
i have all my pics on my phone so please txt me and i can mms you what you need to see.
or see my car sale thread for some pics.
contact 0433 290 801.
cheers
https://www.sau.com.au/forums/topic/384532-parting-my-car/
gearbox shifted and sounded perfect. was out of a 110,000km car.
i never drifted it only did a grip day, and that was more a test for the motor, so it hasnt done hard work.
https://www.sau.com.au/forums/topic/384532-parting-my-car/#findComment-6135782
shell - $4500
1993 mspec r32
Clean rego'd shell
sunroof
gtr front guards
rear camber arms
front caster arms
hicas lock bar
origin s13 boot lip
CF vented bonnet
bolt on rear guards
r34 gtt front brakes with slotted rotors, A1RM pads
nolathene bushes up front
3inch cat back
comes with fmic and piping to suit forward plenum
has engine loom to suit rb25 in r32
CD player, front splits and 6x9 rears
VSKF - $300018x9-6 and 18x10.5 -5225/40 and 235/40 neutons black with chrome dish
cusco 2way diff - $750
fuel setup - $500
s2 splitfires - $450
sms me for pics - 0433290801
https://www.sau.com.au/forums/topic/384532-parting-my-car/#findComment-6156637
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
    • Absolutely. Look very closely at the photo (of yours) that I took my second snip of. See how the sill is thicker material right behind the pinchweld, where the two notches are? That is the factory reinforced area for lifting. That pad is supposed to carry the weight. The factory jack (go look at it, and how it interfaces with the car at the pinchweld) shows you exactly how the load is carried from the car to the jack to the ground.
