http://perth.gumtree...QAdIdZ334826541
ECR33 GTS-T
ENGINE WORK:
Car Body Has 174 000ks
Rb25 Engine Has Only 54 000ks
Machined Block Balanced Internals
Ported & Reconditioned Head
Metal HeadGasket
Forged Piston Kit
R33 Gtr Crank
Main Bearings Inner
Main Bearing Centre
Forged H-Beam ConRods
Valve Springs
PonCams NVCS
Lifter Shim
Valve Spring Sheet
Valve Guide Set
850cc Sard Injectors on Side rail
Bosch o44 Fuel Pump
Main Studs Set
Reinforced Washer Set
6 Boost Manifold
ViPec Ecu / Cold Start / Boost Cut / Very Safe Tune / Wont boost untill oil temperature is safe.
Tomei Oil Cap
Koyorad Aluminium Radiator
Auto Bahn Oil Cooler
Garret gt3082r turbo gt35r Housing
R32 Gtr Intercooler
Custom Intercooler Piping
Greddy Plenum
LSD Diff
Engine Strut Brace
Tial External Wastegate 50mm
Screamer Pipe
Exhaust System
Turbo Bag
GTR Brakes
Battery Relocated in boot
Exhaust Heat Wrapping
Clear Timing belt Cover
Turbo Smart Blow off valve
Greddy Oil Catch Can
Braided Hoses Turbo Side
Braided Hoses Oil Cooler
Braided Hoses For Heads + Catch Can
Excedy Hyper Twin Plate Clutch with lightened Flywheel
Comes with permits for some mods
I have tried to remember what i can but have probably forgotten something.
Auto Meter Boost Gauge
Auto Meter Oil Pressure Gauge
Pioneer CD deck + Sound System just no Sub
Nismo Gear Shifter
Nismo Cluster Blue Light
E Nardi Steering Wheel
Coil Over Suspension
Also comes with another set of rims included
Comes with 400r Front bumper
18 inch chromes on the car set of 4
18 inch Gmax Sports Rims also set of 4
Serious buyers only wont sell the car to anyone still on P plates as it is not a toy.
PM for Mobile Number, Serious Offers only, The car will be driven by me, No Tyre kickers or P Platers as stated above.
Edited by Jake91
https://www.sau.com.au/forums/topic/384545-r33-gts-t-a-true-forged-monster/
    • Looking for a S2 front grill for an R34 GT/GTT Doesn’t have to be in excellent condition as I’m looking to paint it. Would preferred if the clips were around.    The $500 this marketplace guy is asking sounds ridiculous in my opinion.
    • Nah, just take the other one off too
    • A mini mini-gun.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
