Well do you have O2 sensors?
If yes - on.
If not - off.
Pretty straight forward :)
That said you do not need to have them, my tune doesn't utilise them. Previous setup/tune I was getting 700kms to a tank on FWY. Now only around 450kms so obviously the tune needs more attention without using O2 sensors.
Also to note, if you find your idle is a bit up/down it can be O2 sensor(s) failing. Turning them off is a quick way to confirm/deny they are the issue as if you turn them to OFF an idle stabilises - you know they are failing/dead.
It allows you to select between the 32 and 33 type o2 sensors. I don't know which squiggle yours is set to, but if you go to sensor check and both o2 sensors flick around 0.5v average at idle, you have it set right.
If they don't average 0.5v at idle, one or both sensors are dead, or you have it set the wrong way
Yea... this is choose between r32 and r33 gtr as they use different type O2 sensors.
Not sure but the older pfc probably didnt have the option due to the fact that r33 wasnt even built at the time, but the newer pfc definitely has it.
This needs to be on for R32 and off(+ sign) for R33 gtr
But as mentioned before if you have O2 F/B control off, it should not make a difference
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
