Chris would proberbly know. From what I've seen playing with mine is they are powered so I jumper or something is needed on the non option deck to power it. Also haven't seen back of a non Bose radio so don't know if they got the space for the plug.
also, no, there is no wiring to the sub for the non-bose cars. but there is an amp built into the sub enclosure, so it wouldnt be difficult to work out the power wires and the audio input
no mate i dont, im lacking the mounting screw for the sub to hold it and the spare wheel into the wheel well.
if i did, id have it hooked up already! i THINK it uses a speaker level input from the amps that are usually in the boot of the bose equipped models.
from an aftermarket head unit, i wouldnt imagine it would be too hard to wire up.
for $80 its worth taking the risk! lol
as a FYI. these need at least a 6Vpp balanced signal into them to run properly.
if its still available can you take a measurement from the base to the top of it. I want to see if I can get it in the spare tyre well of my R32.
Hi there, I am in Adelaide & also interested. I have sent you a PM.
you would be better off with the 6x9s that go in the rear shelf of yours..
Would you have any recommendations? While you are at it what about the fronts also? I know that it is subject to personal taste & budget but maybe a rough guide would interest a few people.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
