I'm selling my R32 so I won't need these parts.
http://www.skylinesaustralia.com/forums/topic/384502-r32-gts-t-manual-sedan/
Used parts
Complete R32 RB25DE motor (131,000 Km) $500
RB25DET block with cradle and oil squirters. $150
R32GTR crankshaft with wide oil-pump collar. $400
Set of GTR conrods. $200
Set of GTR 444cc injectors. $120
HKS GT2530 turbo. $900
Apexi boost control solenoid. $80
New stuff
R32gtst Apexi/ AP Engineering Power FCWith commander BNIB $1400
Z32 Air flow meter New in sealed bag. $250
Wiseco 87mm forged pistons with teflon coating. $800
ARP conrod bolts. $100
ACL Race conrod and main bearings. $300
Genuine Nissan engine rebuild gasket set. $180
Cometic head gasket. $ 150
Pr. Nismo engine mounts. $100
Bos imports Stainless steel split front pipe
with divide removed to suit HKS GT25 series turbo. $350
I'm not keen on splitting it up too much.
I'll consider offers on the lot.
Located Lismore NSW
Ph. 0266 251 365
https://www.sau.com.au/forums/topic/384576-r32-engine-build-parts/
The injectors bolt straight in to the rb20 but you need to rewire the injector loom to put a ballast resistor in line.
There is a thread in the tech section on how to do it.
The injectors were removed from a low ks r33gtr and were cleaned and placed in a sealed bag.
I would always get a set of used injectors serviced before fitting anyway.
The AFM is also a bolt in fit but you will need a remap to run it.
Used parts
New stuff
Located Lismore NSW
Is the gasket kit the full motor set including head gasket. I'll take it if you will post to 4174. Call or text 0414 236 724
Ph. 0266 251 365
As you can see by the link in my initial post I have my 32 for sale.
I'm not keen on selling the parts before I sell the car because if the car doesn't sell
I'd like to complete my project later on.
I've had a lot of interest in some of the smaller items but I've been asking people to wait.
At the moment I'm noting your interest and if there is interest in enough items I'll split the parts up before the car sells.
hks 2530... specs? flange type? exhaust housing? shaft play? km's? pm me cash price please mate
Flange type is Rb20/25 skyline. It is actually a full skyline kit with oil lines, elbow and silicon joiners.
I was told it was used for 8000kms.
Play is minimal, virtually as new.
The only question mark over it is that it has been in storage for a fair while.
Best to seek advice as to whether these things are ok if they have been sitting.
I had the split dump front pipe modified to match it so I'd prefer to sell them together.
When I have buyers for enough stuff I'll let the turbo and front pipe go for $1000.
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
