I'm selling my R32 so I won't need these parts.
http://www.skylinesaustralia.com/forums/topic/384502-r32-gts-t-manual-sedan/
Used parts
Complete R32 RB25DE motor (131,000 Km) $500
RB25DET block with cradle and oil squirters. $150
R32GTR crankshaft with wide oil-pump collar. $400
Set of GTR conrods. $200
Set of GTR 444cc injectors. $120
HKS GT2530 turbo. $900
Apexi boost control solenoid. $80
New stuff
R32gtst Apexi/ AP Engineering Power FCWith commander BNIB $1400
Z32 Air flow meter New in sealed bag. $250
Wiseco 87mm forged pistons with teflon coating. $800
ARP conrod bolts. $100
ACL Race conrod and main bearings. $300
Genuine Nissan engine rebuild gasket set. $180
Cometic head gasket. $ 150
Pr. Nismo engine mounts. $100
Bos imports Stainless steel split front pipe
with divide removed to suit HKS GT25 series turbo. $350
I'm not keen on splitting it up too much.
I'll consider offers on the lot.
Located Lismore NSW
Ph. 0266 251 365
https://www.sau.com.au/forums/topic/384576-r32-engine-build-parts/
The injectors bolt straight in to the rb20 but you need to rewire the injector loom to put a ballast resistor in line.
There is a thread in the tech section on how to do it.
The injectors were removed from a low ks r33gtr and were cleaned and placed in a sealed bag.
I would always get a set of used injectors serviced before fitting anyway.
The AFM is also a bolt in fit but you will need a remap to run it.
Used parts
New stuff
Located Lismore NSW
Is the gasket kit the full motor set including head gasket. I'll take it if you will post to 4174. Call or text 0414 236 724
Ph. 0266 251 365
As you can see by the link in my initial post I have my 32 for sale.
I'm not keen on selling the parts before I sell the car because if the car doesn't sell
I'd like to complete my project later on.
I've had a lot of interest in some of the smaller items but I've been asking people to wait.
At the moment I'm noting your interest and if there is interest in enough items I'll split the parts up before the car sells.
hks 2530... specs? flange type? exhaust housing? shaft play? km's? pm me cash price please mate
Flange type is Rb20/25 skyline. It is actually a full skyline kit with oil lines, elbow and silicon joiners.
I was told it was used for 8000kms.
Play is minimal, virtually as new.
The only question mark over it is that it has been in storage for a fair while.
Best to seek advice as to whether these things are ok if they have been sitting.
I had the split dump front pipe modified to match it so I'd prefer to sell them together.
When I have buyers for enough stuff I'll let the turbo and front pipe go for $1000.
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
