Are there any downsides to highflows or are they just as good as the aftermarket ones..
Standard ones can be highflowed to 740cc I believe..whats the cost roughly??
quik google found these..anyone know if they are they any good
http://www.fiveomotorsport.com/import-high-performance-fuel-injectors/nissan
https://www.sau.com.au/forums/topic/384609-injectors/
Unfortunately I've had the opposite experience.
Remember the most important thing about an injector is how it atomises fuel, not how much fuel it can pass at 100% open. You will literally require 20% less fuel from an efficient injector/one designed for your intake manifold setup.
Unfortunately running a drill through an injector is not exactly precision engineering. I would want to see a standard and hi flow injector side by side on a flow tester, looking at the spray pattern before I would accept it is OK.
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135326
I have a few at home. I might video them on the flow bench at 43psi to see when i get a chance. I farkin hate testing side feeds but. Pain in the butt. Need to make up a sr fuel rail jig instead of the machined alloy blocks.
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135356
They were hiflow standard injectors (back in the old days, race regs required standard injectors but they did not specifically exclude hiflowing). Instead of having a nice cone spray like a standard injector, it was more like looking at a garden hose. The problem basically was the high flow injectors would not make any more power, they would just use more fuel.....worst of both worlds.
Also, from a tuning perspective, unless it was tuned really rich it would ping like it didn't have enough fuel. Which in hindsight was perfectly clear because the fuel was there but was not being burned properly because it wasn't atomised properly.
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135379
BTW...cost of obtaining, cleaning and hiflowing an injector are pretty bad compared to a properly designed, new injector too. So it doesn't really make sense to me either way these days - big, suitable injectors are available outrageously cheap these days
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135382
I left my SR fuel rail at the injector shop >_< ...that would definately be interesting to see though. I believe the fiveo ones are brand new units that have been hiflowed..maybe they have done a better job than just drilling a bigger hole...maybe not..
I do understand what you mean about atomisation which is why im concerned, but unless I find some nismos cheap I have to look at other options..deatschwerks were others i was considering, About 500$ i have found them for..might have been US though $
arent siemens or someone making some more affordable injectors too now..
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135599
I looked at Deatschwerks vs other options and there were too many question marks.
PHR on here do ID1000s cheap. Just do it!
who what where???
ed..went through powerhouse site..then remembered id1000s are top feed, i need side feed..
unless i get a new plenum..hmmm..nahh!!!
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135601
Pretty sure removing the pintle caps from the stock injectors doubles your flow rate.
The injector isnt damaged in any way on the inside and can still function as it should, but the spray pattern is effected as described aboved. how bad it is im not sure... but I can say bad fuel consumption is to be expected
have owned a set of these done by ceffie
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135618
i posted a thread in regards to this it was a couple of pages long it soon made me think that i should go the deatchwerks injectors but it one of those things like what is the best turbo for a rb25 depends really like if its a daily and you want fuel economy etc
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135708
while were talking bout high flow injectors, i bought some second hand injectors which were private sale, there were advertised as "nismo 555cc injectors", they are yellow on top, 4 holes and side feed
Problem is the numbers cant be identified on google and searches ive done , they have U.J A46-Z00 on them, ive heard there just highflowed standards possibly.
are these going to work for 300rwkw? i was told they made 270, but i dont know. Will have them tested , but any opinions?
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6137652
if they are they've been repainted. i doubt they are though, ask the seller for part numbers?
yes they dont look very red do they..but they do look very much like nismos otherwise..
I looked around for images and notice while some look bright red , under different lighting they will look more brown..So im a bit confused..awaiting reply form seller..
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6137726
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
