Are there any downsides to highflows or are they just as good as the aftermarket ones..
Standard ones can be highflowed to 740cc I believe..whats the cost roughly??
quik google found these..anyone know if they are they any good
http://www.fiveomotorsport.com/import-high-performance-fuel-injectors/nissan
https://www.sau.com.au/forums/topic/384609-injectors/
Unfortunately I've had the opposite experience.
Remember the most important thing about an injector is how it atomises fuel, not how much fuel it can pass at 100% open. You will literally require 20% less fuel from an efficient injector/one designed for your intake manifold setup.
Unfortunately running a drill through an injector is not exactly precision engineering. I would want to see a standard and hi flow injector side by side on a flow tester, looking at the spray pattern before I would accept it is OK.
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135326
I have a few at home. I might video them on the flow bench at 43psi to see when i get a chance. I farkin hate testing side feeds but. Pain in the butt. Need to make up a sr fuel rail jig instead of the machined alloy blocks.
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135356
They were hiflow standard injectors (back in the old days, race regs required standard injectors but they did not specifically exclude hiflowing). Instead of having a nice cone spray like a standard injector, it was more like looking at a garden hose. The problem basically was the high flow injectors would not make any more power, they would just use more fuel.....worst of both worlds.
Also, from a tuning perspective, unless it was tuned really rich it would ping like it didn't have enough fuel. Which in hindsight was perfectly clear because the fuel was there but was not being burned properly because it wasn't atomised properly.
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135379
BTW...cost of obtaining, cleaning and hiflowing an injector are pretty bad compared to a properly designed, new injector too. So it doesn't really make sense to me either way these days - big, suitable injectors are available outrageously cheap these days
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135382
I left my SR fuel rail at the injector shop >_< ...that would definately be interesting to see though. I believe the fiveo ones are brand new units that have been hiflowed..maybe they have done a better job than just drilling a bigger hole...maybe not..
I do understand what you mean about atomisation which is why im concerned, but unless I find some nismos cheap I have to look at other options..deatschwerks were others i was considering, About 500$ i have found them for..might have been US though $
arent siemens or someone making some more affordable injectors too now..
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135599
I looked at Deatschwerks vs other options and there were too many question marks.
PHR on here do ID1000s cheap. Just do it!
who what where???
ed..went through powerhouse site..then remembered id1000s are top feed, i need side feed..
unless i get a new plenum..hmmm..nahh!!!
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135601
Pretty sure removing the pintle caps from the stock injectors doubles your flow rate.
The injector isnt damaged in any way on the inside and can still function as it should, but the spray pattern is effected as described aboved. how bad it is im not sure... but I can say bad fuel consumption is to be expected
have owned a set of these done by ceffie
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135618
i posted a thread in regards to this it was a couple of pages long it soon made me think that i should go the deatchwerks injectors but it one of those things like what is the best turbo for a rb25 depends really like if its a daily and you want fuel economy etc
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6135708
while were talking bout high flow injectors, i bought some second hand injectors which were private sale, there were advertised as "nismo 555cc injectors", they are yellow on top, 4 holes and side feed
Problem is the numbers cant be identified on google and searches ive done , they have U.J A46-Z00 on them, ive heard there just highflowed standards possibly.
are these going to work for 300rwkw? i was told they made 270, but i dont know. Will have them tested , but any opinions?
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6137652
if they are they've been repainted. i doubt they are though, ask the seller for part numbers?
yes they dont look very red do they..but they do look very much like nismos otherwise..
I looked around for images and notice while some look bright red , under different lighting they will look more brown..So im a bit confused..awaiting reply form seller..
https://www.sau.com.au/forums/topic/384609-injectors/#findComment-6137726
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
