hey guys I have another car for wrecking again
is a 1996 S2 R33 Manual
RB25DET long motor leak down tested all appears to be in excellent running order $1600
R33 RB25DET turbocharger $350
5 stud turbo brake calipers and discs front and rear $800 for a full set calipers have had all new seals and rubber bits done by power brakes
5 stud conversion front and rear $350
Flywheel and Excedy clutch $200
5 Speed manual box $1600 includes a yoke and crossmember if you need one
pulled down, hot tanked, checked for wear, all components that are used in my gearboxes are %100 genuine OEM parts (from main north Nissan) this box has a full brand new gearstick and all new control bushes
Front Bumper support got a little dent in it so $80
front fog / indicator light assembly $80 each left and right the wiring plugs are a bit howyougoing but they still look perdy
R33 S2 VLSD diff $200
5 bolt drive shafts need new boots $50 the pair
Apexi SR muffler.. $200
I have mountains of skyline mechanical bits just send me a PM or call 0447713034 and all prices are negotiable
https://www.sau.com.au/forums/topic/384611-wrecking-r33-s2-rb25det-manual/
Adelaide and I have a few 3 inch cats one has no name the other one has redback on its
no 3 inch dumps sorry
and edit.. the turbo has the carbon fiber compressor wheel
Edited by DYNOBUSTER
I'm unsure on 2 things with the gearbox:
You say it's been pulled down - has it had any bearings or synchros replaced?
Also - does it come with the clutch pictured, and if so what clutch is it?
Cheers :)
Cheers :)
the gearbox has been pulled down tanked and fully inspected for wear (synchro clearances measured) and damage the only parts requiring replacement were parts of the selectors the gearstick and all the control bushings in the extension housing this is what people in the trade call "reconditioned" but I'm a bit more honest than most
if you buy the box for what I'm asking I'll include the clutch that's pictured
and as for the clutch's I have five
HKS twin plate ceramic type (its a re-branded Tilton 7.25 quarter master clutch) RB (20 25 26 30)
ATS carbon twin plate and flywheel push type suit RB (20 25 26 30)
ATS carbon twin plate push type and flywheel suit VQ35 VQ37 and probably others (was in a 350Z)
a heavy duty organic extreme clutch and flywheel for R33 S2
and the one pictured an Excedy organic plate looks like a standard replacement one with a fair bit of meat left on it good to get you out of trouble
also I have a pair of caster rods with new noltec bushes $100 the pair
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
    • So, weld a plate with the Mines logo laser cut into it, onto it. Instant Mines pipes, whether they were or weren't originally.
    • I don't know if the blocks are "the same". They will be very very similar. Obviously, either the bore or the stroke is going to be bigger on the 20. If the bore is bigger, then the 18 head is unlikely to fit properly. If the bore is the same, then you can almost certainly fit the CA18 head, but there migth be a few fun things you have to do to make water galleries (or other things) line up properly. Or... it could just be real easy. Is it worth the effort? Almost certainly not. You can make nearly as much power on a 2 valv ehead as you can on a 4 valve. There's not any "magic" in a 4 valve head.
    • Yes, me too!!!!  I need to find a something that has all the abbreviations for what these cars have LOL
