hey guys I have another car for wrecking again
is a 1996 S2 R33 Manual
RB25DET long motor leak down tested all appears to be in excellent running order $1600
R33 RB25DET turbocharger $350
5 stud turbo brake calipers and discs front and rear $800 for a full set calipers have had all new seals and rubber bits done by power brakes
5 stud conversion front and rear $350
Flywheel and Excedy clutch $200
5 Speed manual box $1600 includes a yoke and crossmember if you need one
pulled down, hot tanked, checked for wear, all components that are used in my gearboxes are %100 genuine OEM parts (from main north Nissan) this box has a full brand new gearstick and all new control bushes
Front Bumper support got a little dent in it so $80
front fog / indicator light assembly $80 each left and right the wiring plugs are a bit howyougoing but they still look perdy
R33 S2 VLSD diff $200
5 bolt drive shafts need new boots $50 the pair
Apexi SR muffler.. $200
I have mountains of skyline mechanical bits just send me a PM or call 0447713034 and all prices are negotiable
https://www.sau.com.au/forums/topic/384611-wrecking-r33-s2-rb25det-manual/
Adelaide and I have a few 3 inch cats one has no name the other one has redback on its
no 3 inch dumps sorry
and edit.. the turbo has the carbon fiber compressor wheel
Edited by DYNOBUSTER
I'm unsure on 2 things with the gearbox:
You say it's been pulled down - has it had any bearings or synchros replaced?
Also - does it come with the clutch pictured, and if so what clutch is it?
Cheers :)
Cheers :)
the gearbox has been pulled down tanked and fully inspected for wear (synchro clearances measured) and damage the only parts requiring replacement were parts of the selectors the gearstick and all the control bushings in the extension housing this is what people in the trade call "reconditioned" but I'm a bit more honest than most
if you buy the box for what I'm asking I'll include the clutch that's pictured
and as for the clutch's I have five
HKS twin plate ceramic type (its a re-branded Tilton 7.25 quarter master clutch) RB (20 25 26 30)
ATS carbon twin plate and flywheel push type suit RB (20 25 26 30)
ATS carbon twin plate push type and flywheel suit VQ35 VQ37 and probably others (was in a 350Z)
a heavy duty organic extreme clutch and flywheel for R33 S2
and the one pictured an Excedy organic plate looks like a standard replacement one with a fair bit of meat left on it good to get you out of trouble
also I have a pair of caster rods with new noltec bushes $100 the pair
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
