Set the cam gears back to 0 on both and do a pull on the dyno 8 and 4 is not ordinary.
I had this probelm with my car, I got diffrent cams but it still came down to the inlet being to advanced if I remember right.
  • Replies 75
Posted Images
Never had the car on the dyno before turbos etc were fitted because there are no 4 wheel dynos anywhere near where I live. I Bought everything myself then took the car down to have everything fitted and tuned and had to stay a few days in Sydney while it was being done.
I'm in Singleton (north of newcastle)
Oh really? So how do I know what compression I should be looking for? Lol. Now that you pay that I'm not so sure I want a local mechanic to do it because if It's not a falcon or commodore they don't seem to know what they're talking about.
thanks for that. I think I'm gonna just wait and take the car to DVS_JET to get him to do the test as he knows more about the rb engines than anyone up this way. We'll see how that comes back and if It's all good I'll see if he can try to figure out what he can on the dyno and testing some other things.
    • Unless things that you want to do include reference to time. Simple Boolean logic is only good for digital inputs or analogues that have been thresholded into digitals. But unless you also have a timer function available (which would more ideally be located inside the program, rather than being forced to implement a timer outside the ECU and bring it in as a seperate digital for every time delay you want to implement), then you can't do some of the things that you might want to do. My PLC ladder logics are obviously littered with program blocks, because that's easier than building it all in ladder gates, but the most frequent of those program blocks is a simple timer, because you actually can't otherwise do that in ladder at all.
    • Log voltage. I'm suspecting the alternator. Or even maybe a bad earth somewhere. ie, seeing as it is rev dependent, I am thinking it is alternator dependent.
    • Yeah so N1 and any other larger than factory pump are pretty famous for pumping the sump dry...obviously we don't often get to spend 20 or 30 seconds at high rpm/full noise on the road so I'd still be suspicious that is what is happening here.
    • You are also getting pressure dips on gear shifts. They're just not dipping as far, but they're dipping quite below the amount of oil pressure you should be seeing, for how much RPM drops.   It quite little could be the oil pressure relief valve is starting to stick open a little/is slow to close.
    • Can you log battery voltage, and TPS, and put all four of those into a single image (even as split graphs)?   The oil pressure drops aren't following RPM as such. I'm intrigued if you may have a ground loop between different sensors. With the engine not running, log your sensors and for example cycle the throttle pedal. See if any sensor values flutter or move about. This won't be a perfect test either as the ECU won't be cycling all of its actuators like it would be while running. What EMTRON do you have? Do you have a link to the wiring guide for that ECU?
