Looking for a close best. I'm changing over to a big single twin scroll.
sizes: 1.01
1.15
1.28
1.44
Changing injectors, Full Race manifold,4" exhaust ,Pump all the normal but here's the mod list as of now.
Engine mods:
Tomei stroker crankshaft
Crower rods
JE pistons
Apex’I AX 53B60 turbos with P21 housings
HKS exhaust manifolds
HKS O2 housings
HKS 1.5mm head gasket
HKS front mount intercooler
HKS hard pipe kit
Ferrera valvetrain
Tomei 270* cams, intake and exhaust
Tomei cam gears
Extreme Cylinder Head stage 5 port work
Nismo 3.5" exhaust
Nismo downpipes
Nismo 780cc injectors
Nismo fuel pump
AEM EMS V1 w/ wideband
https://www.sau.com.au/forums/topic/384652-best-ar-for-a-gtx4294r/
It'd be 1.28 or 1.44 for that size turbo, if you intended on making the power.
1.15 if you wanted to pull response in, but loose a bit up top.
1.01 i don't think is even worth worrying about.
What has the builder/turbo people said about it?
What do you want from the setup?
Full Race Geoff played with RB26s some years ago so you could do well to ask him .
You should also at least look at T51Rs because they are essentially a GT4294R with arguably a more responsive T51 (I think) 76 trim turbine wheel . Its the one HKS uses and I pretty sure you can buy the same cartridge but with Garrett housings .
Your call but I would base the engine on an RB30 because every inch counts .
A .
i have a step 3 rb28 running same turbo and i use the 1.28 and have 280° 11.5 lift cams it makes 600hp on 18psi on bp98 and comes on boost at 6000rpm and it makes 800hp on 30psi on BP109 hope that helps any othe questions feel free to pm and i also run 1000cc injectors and two walbro 225 pumps
Edited by 260rsstagea
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
