  • Replies 93
Popular Days
Hard core technical stuff and lots of it. Turbo sizing, suspension tuning, fuel system designing, tire tests, head porting, aerodynamics that work, ongoing project car diaries, performance driving articles, etc etc.
There are too many eye-candy/advertising import mags out there already, the last thing we need is another one.
Couldn't agree more. I want comparisons, reviews, technical articles, etc, etc. If I wanted eye-candy I would just search the web instead of forking out dosh for a mag.
LW.
LW.
yup technical stuff is where it's at. There's already lots of poster/girls on cars mags out there, but aside from zoom and the odd pieces scattered around in various mags there's not a huge technical base out there.
What do uz think about the engine tuning like in speed?
it's a good idea that both speed and zoom seem to cover quite well with different approaches, but what about chassis tuning?? Both speed and zoom tend to concentrate on the go parts of the equation without really touching on suspension/brake tuning. No point making all that power when you can't put it to the ground and stop yourself after it
:D
women in clothes, women in less clothes, women in nearly no clothes and women with no clothes. =)
:boobs: :P
I want to learn about engine management systems, You could also do an article on turbo sizing, what combo's do and do not work. I would be happy with a 12 sec street car :P But its finding out what needs to be done to get there.
Sumo
P.S. a few boobies would certainly make it easier on the eyes
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
