Ive been reading but I want to be 100%.
Just wanted to know it if it is a good idea to install LOW (not superlow) King springs into my r34 skyline. Ive been reading around that superlows damage the stock shocks of skylines so Im not keen on ruining my shocks for looks. But will LOWS do the same?
Does anybody have experience with this ? I have a nismo bodky on my skyline already but just wanted to drop it down a little more. King springs im after are the KDFL-101 in the King spring catalogue http://www.kingsprings.com.au/catalogue/kings_master_catalogue.pdf.
Before anyone mentions coilovers I just want to know if this will be a suitable option at the moment as it costs less and if it isnt worth it, ill invest in coilovers in the future.
thanks
https://www.sau.com.au/forums/topic/384673-r34-king-springs/
Lows should be OK. Only OK though....not good. The maths is pretty simple. If you want to go lower, then then springs have to be stiffer. If you have stiffer springs, then you really need uprated dampers to control the springs. Otherwise you get a bouncy piece of shit as a result.
Now, stock R34 dampers are all quite old. And so they're not likely to be even as good as they were new. So they're going to struggle to damp out stiffer springs. So my advice is not to just buy springs. If you can't afford a set of springs and at least a set of Bilsteins or KYBs right now, then wait.
King springs lows will be fine in the standard shocks (if they are in good cond). I had $3000 bilsteins coilovers in my 34 gtr and were a bit to hard for me - put the lows in with standard shocks and it's all good.
If you on a budget, then yes, it will be cheaper then getting a full adjustable coil over setup.
I have used King Springs before but in my daily + I would also look into Nismo / Tein / Bilsteins / KYB Springs.
As of my personal choice, I'd just got full adjustable coil over set up.
Tein / Cusco / HKS / Bilsteins, just to name a few.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
