HEY ALL,
I have these parts left over from previous builds, everything must go will accept reasonalble offers. Have plenty of pics of every part available. PM me if you have any questions.. located near Liverpool NSW
I will keep updating this with more parts or anything that is sold
RB26 USED OIL PUMP $200
post-59990-0-73729800-1322814533_thumb.jpgpost-59990-0-40126000-1322814570_thumb.jpgpost-59990-0-67246200-1322814823_thumb.jpg
RB25 Brand New Tensioner $30
Delphi 600cc top feed injectors $250
post-59990-0-17467300-1322807876_thumb.jpgpost-59990-0-10772200-1322807924_thumb.jpgpost-59990-0-60461100-1322807940_thumb.jpg
HKS USED cam gears came off RB26 $100each
post-59990-0-50095200-1322809672_thumb.jpgpost-59990-0-75634100-1322809792_thumb.jpgpost-59990-0-97158800-1322809812_thumb.jpg
Unknow spec side feed injectors came off SR20 making 250rwkw $150
post-59990-0-31389800-1322817166_thumb.jpgpost-59990-0-28861800-1322817180_thumb.jpgpost-59990-0-75587300-1322817220_thumb.jpg
Rb26 & Rb30 Lower timing covers $30 each
GTR R32 cluster has marks on plastic with wiring loom $30
post-59990-0-36216000-1322815616_thumb.jpgpost-59990-0-48871700-1322815870_thumb.jpgpost-59990-0-19976700-1322816056_thumb.jpg
S14a 200sx cluster looks in good condition no wiring $30
Surge Tank dash 8 supply / dash 8 Return / 2x dash 6 weld on side $50
Ap Racing front Brake kit suit S14/s15 R32/R33 GTR / R33 GTST $2400
post-59990-0-38409300-1322808028_thumb.jpgpost-59990-0-11032700-1322808131_thumb.jpgpost-59990-0-70005300-1322808165_thumb.jpgpost-59990-0-58181100-1322813568_thumb.jpg
Ebay intercooler 600x300x100mm core 3inch in & out made 300kw on a SR20 $50
R33 GTs-t Extrme button clutch has about 50-70% meat held up well with 300kw $200
post-59990-0-83628500-1322809569_thumb.jpgpost-59990-0-98157900-1322809551_thumb.jpgpost-59990-0-03620800-1322809585_thumb.jpgpost-59990-0-61575200-1322809510_thumb.jpg
T3 / T4 adaptor plate, to adapt T3 turbos to T4 manifolds or vice a verca $30
Sr20 standard blow off valve $20
Sr20 Engine fan in great condition $50
K&N 4 inch air filter used $30
Sr20 standard fuel reg $20
S14a quater rear windows $100 each
post-59990-0-95435300-1322815154_thumb.jpgpost-59990-0-31789100-1322815240_thumb.jpgpost-59990-0-40063900-1322815318_thumb.jpg
hpi boost controller $50
post-59990-0-27877300-1322809871_thumb.jpgpost-59990-0-65384900-1322809852_thumb.jpgpost-59990-0-35148500-1322809836_thumb.jpg
Sr20 S14a/s15 OEM coil packs $150
Sr20 engine fuse box cover $10
standard SR20 water pump pulley painted blue $20
R33 GTST series 1 front bar GTR style has been butched around intercooler $50 ono
R33 GTST series 1 Grill $50
R33 GTST rear spoiler $30
post-59990-0-69598100-1322809243_thumb.jpgpost-59990-0-72995000-1322809257_thumb.jpgpost-59990-0-48480600-1322809456_thumb.jpg
Sr20 starter motor $50
Bosch 044 Pump holder $30
S14 throtle body $50
TurboXS blow off valve $50
Hey
ill take the tensioner and does that boost controller come with the rest of the harness? if so ill take that too
hi mate,
the rest of the harnest is in my complete wiring loom.
i have the complete wiring loom out of the car and in a trolley. i have tried looking for the little plug/harnest and its hard to find...
ill have anther check today or tomorrow. whats your loaction?
How many km on the clutch? How has it been treated (ie abuse etc)
the clutch has around 5K-7K on it street driving never hit the track.. i have put 1000cc injectors in for e85 tune so upgraded clutch as well,
BRAND NEW Bride COPY seats x2 with Rails never fitted in car or sat on been stored inside. $1400ONO
rails suit s14 should fit other silvias..
classifieds-65535-0-33871900-1322962718.jpgclassifieds-65535-0-07540200-1322962735.jpgclassifieds-65535-0-18230900-1322962748.jpg
classifieds-65535-0-65961400-1322962776.jpgclassifieds-65535-0-25136500-1322962794.jpgclassifieds-65535-0-57528500-1322962760.jpg
Edited by BMYHOE
Delphi 600cc top feed injectors, will these fit straight into an rb20det?
im not sure what rail is on the RB20's.
these are TOP FEED injectors
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
