Hey guys, i went to inspect and test drive a r34 gtt today.
The seller doesn't know anything about the modifications done to it (though it looks like the only thing that has been changed is the exhaust and turbo timer installed).
I was just wondering how do i know if the car has an immobiliser, and if it doesn't have one (i'll find out next time) what is the most affordable (BUT DECENT) immobiliser to get and where to get it from?? I live in NSW in the Hils area.
thanks!
(edit) and i just read somewhere on this forum that turbo timers are a defect. Is that still the case?? Because if it is, I don't mind taking it out and just sitting with the car for a minute after i drive it, or just drive normally for the last 1-5mins of my trip lol.
Edited by suwidji
thanks!
if it is ABSOLUTELY stock - it will not have one.
Is there anywhere I can take the car to, and they can tell me exactly what mods are on the car?
Im getting stateroads to check it out for a comprehensive inspection, would they be able to tell me what's been done to the car at all?
ok thanks guys.
Also, my initial question was about the immobiliser lols. any ideas on that?
Why is it so hard to figure this one out? lock it while you're sitting inside it and try to start the engine? if it wont start then its got an immobiliser?
lol thanks, I'm very very very noob around cars, just learning :) but thanks.
also (probably another dumb question) my mate has an r34 and his headlights have "xenon" written on em, but his headlights are yellow when turned on. Aren't xenon's supposed to be like white/blue-ish in colour?
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
