halp!
so anyways having issues with sau at the moment. at the moment the only way i can post is by using fast reply or starting a new thread. i've attached some screen shots, can anyone tell me why this is happening?
the first one is how the forums all look. they aren't nearly as wide as they should be, and it cramps everything up. it should fill that entire white area??
also heres what the screen looks like when i try to post a reply.
wtf is this? i try to go to my user settings page and i get this...
most pages of the site have same/similar issues for me atm wtf is it?
ok so it turns out if i refresh a page 10 times it'll go back to normal (which is how i've made this thread in the first place), but then next page i load goes back to being retarded. has anyone any ideas?
https://www.sau.com.au/forums/topic/384722-having-issues-viewing-sau/
As you said if you refreshed a few times it worked, Im thinking antivirus or a local PC problem of some description.
Unfortunately what it is, i do not know.
bottom left drop down box change cyantic to IP board ;)
Cyantic Import is fine - I use it, and have since the day it was loaded :)
Same and I've tried in Safari, Firefox and Google Chrome and it aint my computer.
Another link with troubles here...
http://www.skylinesaustralia.com/forums/topic/384869-problems-with-this-site/
i have just switched on my laptop, which i don't often use. the last time it would have been on the net was a while before i started having problems with sau on my desktop. my laptop also now has the same issue viewing sau and only sau. since the laptop doesnt get used much, there isn't much in the way of software on it. a year ago i did a clean install of win7 ultimate x64, since then its had office, chrome, MSE (antivirus), itunes... that is literally about all it has on it. have tried disabling/playing with MSE and no luck.
very frustrating
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
