Nope. But your answer is very random, like you just rolled a dice and it said 'timing'.
You're going I need to fault find and give us more information if you even want a slight guess from anyone here.
You didn't even have the decency to list any mods.
Is he running a t88, rb34 stroker, NOS and twin rear mounted secondary turbos?
Edited by The Mafia
https://www.sau.com.au/forums/topic/384728-r34-gtt-issue/#findComment-6137116
Will do, bsa. Mafia if he had all them mods dont u think i would have told him to get the service done were all the other work was done? Its a stocker with a front mount cooler and full exhaust, happy trolling?
https://www.sau.com.au/forums/topic/384728-r34-gtt-issue/#findComment-6137121
Pull the plugs out re gap to .8 or .9 is he running stock boost? Also check all loom plugs are connected properly. If that still don't work check piping for rags most unlikely but never trust some one unless you know they are capable on rb engines they can be sensitive
https://www.sau.com.au/forums/topic/384728-r34-gtt-issue/#findComment-6137128
did your mate change ignition coils as a part of his 100kkm service? R34 RB25 Neo coils are known to start dying at just about this milage. And they don't usually cease working completely, they may work okay under very light loads, at idle etc, but start causing missfires under heavier loads, i.e. on boost. It usually feels like soft rev limiter has been hit, it also sounds funny. And vibrates.
https://www.sau.com.au/forums/topic/384728-r34-gtt-issue/#findComment-6137181
Even the small mods youve listed can cause issues. Plus, you haven't said why the car was at the mechanical shop, and what the intentions where of the mehanic.
Keep calling me a troll, I'll start calling you an uninformative dickead with an attitude, that expects us to look into a crystal ball and just magically come up with an answer, with very little to almost no information.
When you post an issue on skylines Australia, you post your mods, and the most obvious thing - what was changed before and after the issue.
We can't just guess.
https://www.sau.com.au/forums/topic/384728-r34-gtt-issue/#findComment-6137183
Troll, well ye that seems something to look at legion ill let him know, mafia honestly its hard enough trying to get simple answers but u take it to the next level people are hesitating to ask questions coz assholes like u embaress them im not really switched on about this topic hence my questions no need to scream out loud that im uninformed ur an asshole full stop troll
https://www.sau.com.au/forums/topic/384728-r34-gtt-issue/#findComment-6137397
lol you can forget about getting help on this forum with that attitude
https://www.sau.com.au/forums/topic/384728-r34-gtt-issue/#findComment-6137495
My second post was perfectly valid. Wasn't smart, I was just making a simple point.
But you want to be an uninformative dickhead and blame your ignorance and arrogance someone else - me.
I wasn't trolling, as I said I was making a point. We need to know what has been done to the car, who, how, when, why, etc or we are just wasting our time guessing.
Anyway I say it again, you're an arrogant uninformative dickhead and gave us scraps to work with and then proceeded to call me a troll when I pointed out your lack of info.
Wanker - eat a dick, and go to ns.com
https://www.sau.com.au/forums/topic/384728-r34-gtt-issue/#findComment-6137778
no worse then this forum mate lol
https://www.sau.com.au/forums/topic/384728-r34-gtt-issue/#findComment-6138065
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
