Well I thought these were perfect quality Bronze LMGT4s that came on my B/Blue R34 GT-R from Japan.
18"x10.5" +15
But I didn't realise that...
* on receiving the car, there was gutter rash on 3 of the 4 rims
* as the tyres were being replaced, I could see they were originally white
* as I was going to have them powdercoated, one was cracked
So...
* some months ago, I had the edges of the lips shaved by Magman at Punchbowl
* the cracked rim was bored > TIG welded by Ozwheel at Minchinbury (Paul)
* the 4x rims were powdercoated to "Nismo Black" by Craved Coatings at Penrith (Chris)
And the result is...
And when the car comes along, they'll have Nismo Wheel Nuts to match...
Thanks to the jobs done by the boys up above! :thumbsup:
I know the jobs were progressive over time, but I didn't know what I was going to do with the rims until they matched up with my plans for them to be satin black.
https://www.sau.com.au/forums/topic/384734-lmgt4s-have-a-new-lease-on-life/
  • Replies 54
Looks good Terry,
Chris does nice work dosent he! I have always been happy with his coatings.
Tell me did he put the stickers on then a clear over the top or did you stick them on yourself???
I have to get him to do my lmgt2's but dunno what to do about the sticker.
Nice job on the rims Terry - they look amazing. The stickers look MINT, almost floating under the surface. I guess they've gotta have been put under the clear. I really need to replace the nismo stickers on my LMGT4s, they're looking a bit worn. Might have to order some from RHD.
The nismo wheel nuts I put on mine really set things off too, you're gonna love 'em. I've left mine with all 5 for each wheel for now - really contemplating trying to track down a set of 4 black lock nuts though. The nismo nuts might be 7-sided, but I'm not sure it would deter enough.
Edit: I'm a bit surprised you didn't track down some center-caps for them as well. They really complete the rims in my opinion. When I picked mine up, they were missing, so I sourced some from RHD - totally worth it. Your worry now is if you grabbed some they'd need to be painted to match :(
Hey Terry, what is 'Nismo Black' when it's in a Dulux Powdercoat Colour Selector Chart? I'm tossing up between matt or satin black powdercoat for a set of rims of mine and can't decide. To my eye your finish looks like satin as it is reflecting some light. Any chance you could confirm?
Cheers.
The Omori Edition 'Nismo Black' as they call it is essentially a satin finished black - and this was matched by Chris at Craved Coatings.
I opted for the above process because these LMGT4s are 10.5" wide compared to buying Omori with 9.5" width. Omoris have been available from OTR till recently. Omoris don't have any markings/stickers/embossing to indicate that they are Omoris through my enquiries.
Thanks guys for heads up. Pics of these on the actual car should be up soon. Ta
PS: Dave, I stuck these stickers on afterwards. :yes:
I'm trying to source a set of 4x black flush centre caps atm.
Then again, I could leave the wheels on without any at all.
Then again, I can use these centre caps that were on before.
I'm listening to you guys; and have absorbed what's been said already up above. :rolleyes:
Why dont you order the flat center caps from nengun then get them coated to suit so at least you know its all the same shade.
Im in the process of getting my LMGT3's cleaned up and stuff but will be running without caps due to not being able to source any and the LMGT4 cap setup looks completely different. The joys of LMGT rims having to run Nismo lug nuts because they are the only ones that fit, I have a wasted set of Rays lug nuts here now after finding out the hard way the 19mm head doesn't fit and it has to be 17mm.
Ta Thanks!
I've been communicating on that with Jesse Streeter about the flat centre caps. I'll get some sort of answer this coming week I'm sure.
Yes and I'm fortunate to have the Nismo lug nuts all ready. Black too. Are there any other colours?
nismo lug nuts only come in black as far as I know. I have a set of the long ones here (50mm), When I ordered mine it was actually cheaper to order them from the USA then anywhere I could find in Japan. Also a little bit of randomness the Nismo lug nuts are still slightly heavier then the Rays (thats the long nismo lug nuts compared to the long rays) and I also think I saw somewhere that you shouldn't tighten them with a ratchet gun.
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
