  • Replies 59
What type of Dump pipe has it got? and how well does your driver door line up when you close it??? I think i need new hinges because mine is sagging heaps. Price on each please.(only if dump pipe is not standard)
Hey mate
Just wondering if you have these interior items.
Centre console
3 x aircon clip vents - one on the drivers side two on passenger
Gear stick console (not including the rear compartment)
2 x Door handle covers (just behind the leavers)
Drivers side power windows console (including the hand compartment –small box)
Passenger power window button surroundings
and the passenger side small box just under the door handle
I do notneed any electronics just the plastic surroundings.
ThanksStefan.
