For sale - one of a kind R33 GTS-T (auto) - plenty of go fast bits.
Bargain price for quick sale - $4500 (needs a front bar). I can put 3 months ACT rego on it if required.
Ph: 0434 994 378
A bit of history on the car - I bought this R33 for my wife just under a year ago - paid $12,500 (she really liked the custom look of the rear guards).
A few months later she ran up the back of some clown that was giving way to an invisible car at a roundabout. The R33 only sustained minor damage (cracked front bar, cracked headlight, possible minor radiator damage and a slight kink in the bonnet). The wife went out and bought another car so no longer wants the skyline.
I have since bought new headlights (with HID kit fitted) and a second hand radiator but haven't got around to start work on it (still needs a front bar - I think the bonnet is ok or it may need slight bang work to get the kink out).
My original plan was to fix it up and fit a nitrous kit to have fun at the drags. Due to changing priorities and my yard starting to look like Sam's Hot Car Lot (R33GTR, XB GT Falcon, Magna VRX AWD, Ford Laser, R33 GTS-T, Harley), I've decided to get the car out of my yard.
I thought I would give the locals first dibs at it with a good price. Below is the original advertisement when we bought the car. I can't be certain it has everything the ad claims but I can lay claim that the car is quick - would light the rears up no problem on take off (Auto). It does have a stack of receipts for work done on the car which I can provide.
Here's the original add -
THIS ONE OF A KIND R33 IS OWNED BY A MECHANIC (he was a Leb from Sydney lol really nice bloke though but I don't know for certain he was a mechanic)
This r33 features the following:
  • Custom rear guards
  • 20 inch AVANTI wheels
  • Forged pistons (the leb guy swore on Allah that it has forgies - no receipts because he says he did it himself)
  • 1000cc bosch injectors (I doubt they're that big - wouldn't know the real size)
  • Microtech ECU
  • APEXI AVCR
  • HKS GT25-35 high flow roller bearing turbo
  • Dual stage boost controller (set at 13psi and 20psi)
  • V-port blow off valve
  • 3.5 inch mandrell bent exhaust from turbo back
  • 5 inch cannon muffler
  • HKS air pod
  • Custom split dump pipe
  • PWC front mount intercooler
  • High flow cat
  • Bosch 911 high flow fuel pump
  • Malpassi rising rate fuel regulator
  • Autometer boost gauge
  • Remote engine start
  • Alarm/immobiliser- keyless entry
  • Alpine 6 disc MP3 player
  • Alpine amp
  • Pioneer 6x9's, pioneer tweeters
  • Automatic transmission built up HKS strengthened actuators with apexi state 2 shift kit
Plenty more mods - all work carried out by PULSE PERFORMANC
https://www.sau.com.au/forums/topic/384762-for-sale-1-of-a-kind-r33-gts-t/
I'll be keen on the pump turbo and injectors if you end up parting it :) keep it in mind for me
sorry mate - I'm not interested in turning my yard into a wrecking yard - I want the car gone from my yard.
You can buy it complete, source all the performance parts you wish for your skyline (has everything you will need to get you over the 250rwkw that you are chasing) and part the rest - there's plenty of money to be made there if you can be bothered wrecking it.
Congrats mate
Whats the person doing with it??
Scrapping for parts or purchased for their daughter etc?
thanks mate. The car will be back on Canberra roads cruising around real soon - he's fixing it up for his wife.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
