Hey guys bought some coilovers and put them in last night, as the thread says they are BC Coilovers. Now the front will go lower and sit how i want them to but the rear, but the rears, they do not go as a low as i am wanting... I have never really worked with something like that setup before, the strut and then the rear spring. now with the strut i raised that to as high as it can go, (to make it lower) and then the spring i put i all the way down to it lowest point to make it lower, am i doing this correctly? what do i need to do because i am running 18's on it and it still showing around 25mm off the tyre? I do not want to slam it down all the time, but i just wanted to lower it. I am thinking of going to get a new spring made up from Adelaide, or let me know if i am doing something wrong?
Just wondering because the fronts can go sooooo much lower, but the rear is still pretty high??
Let me know..
https://www.sau.com.au/forums/topic/384766-stagea-bc-coilovers/
you need to shorten the strut and lower the spring at the same time. dont lower the spring too much as it needs to remain captive in the seat at full droop, so it doesnt pop out when you go over a big hole.
From the middle of the wheel, to the guard its 370mm, seems as low as it can go, the front can go so much lower, and i was just wondering why or how i can get the rear lower, you will see in the picture below that i only wanted to lower it like 10-15mm all around, just to sit it down on the rim a little better.
Edited by purezx
Purezx; they should go much lower than that; mine are at 355mm with plenty more thread to go.
I reckon I could get another inch easily.
Hell, look at Jays;382078_10150382772448024_785208023_8373296_1685795364_n.jpg
Have you got some pics of the spring and adjustable perch mounted in position? Not saying you've done it wrong; but something might not be quite right and a photo might show us.:thumbsup:
Have you loosened all of your arm to chassis mounting bolts (pivot points on the subframe) to ensure they aren't bound up? You need to get it on some ramps, so the car is loading the suspension then loosen; maybe even pry open slightly, then retighten all of the lower mounts.
Edit; lol Jase; great minds and all that...:nyaanyaa:
Edited by Daleo
The little wheels wont be helping matters.
lol, they're 18's. Just smaller tires from what I can read. Some 245/45's will fill the guards a bit more. Dale might suggest 245/50's to do the job, but I'd disagree.
General consensus is 245/45 is the best choice for guys running 18's. It's a popular enough size to be affordable. I wouldn't go smaller than that, and was actually thinking of going to 245/50, until Dale talked me out of it. That size has a diameter 77mm bigger, so will really fill those huge guards, but looks could be compromised.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
