  • Replies 53
oh so do you want me to get em? coz I've put in an order for 5 thru already.
I've got updated prices tho... here ya go:
Price of 1.5W CB: 1 Unit = 76.20, 3 Unit = 70.15, 5 Unit = 64.30
Handsfree: 1 Unit = 9.58, 5 Unit = 8.85, 10 Unit = 8.15
Mains Charger: 1 Unit = 9.58, 5 Unit = 8.85, 10 Unit = 8.15
Car Charger 12V: 1 Unit = 9.58, 5 Unit = 8.85, 10 Unit = 8.15
Pouch For CB: 1 Unit = 4.49, 10 Unit = 4.10, 25 Unit = 3.75
yeah funkymonkey, I'll have one of each item on that list.
CB $64.30
3 x Handsfree @ $9.58 = $28.74
2 x Mains Charger @ $9.58 = $19.16
2 x Car Charger @ $9.58 = $19.16
Pouch $4.49
24 x 800mAh AAA batteries @ $1.65 = $39.60 (can you get any better than 800mAh - what are the prices of higher mAh ones?)
Order total = $175.45
Let me know where to transfer the cash and how much postage you want on top (to Northgate, SA, 5085). Probably best to package all the stuff together, post it to me (or someone in SA) and we can dispense the stuff at a cruise or something. I am happy for it all to be sent to me and I can distribute.
Everyone post EXACTLY what they want below so Mr. funkymonkey can put together an order. Thanks mate :)
needs 4 AAA batteries, which don't come with the package (bummer I forgot all about batteries when buyin them).
recommended 800mAh ones. I can get em at $1.65 each if I get a quantity of 25 or more. (so if 7 of you get 4 batteries each it works out). Seeing as the guys in the melb group buy will want some as well that's 5 sets already covered. So if 2 more of you get 4 each then it'll be 1.65 per battery. They are fully rechargable too (which is what the mains n car chargers do they plug into the CB and charge the batteries while they sit in the CB.
Only downside is you can't charge n use the CB at the same time.
oh and i *think* postage is about 5 bucks thru parcel post. It would be easier to ship the entire batch down to one person and you guys all pick em up.
Sort that amongst yourselves n let me know.
sorry guys I like all the goodies :)
so I have to update my order again
1x cb
1x main charger
4x bateries
1x pouch
for me please.
funkymonkey, is it ok to COD to one of us? We'll pay for the service.
how long will this order take?
Nightcrawler, do you mind receiving the COD? I will direct debit your account the money prior to the COD thingy if you dont mind.
Thanks guys
Over :headspin:
nah Dan, I would think that funkymonkey has to pay for the goods to the wholesaler upfront, so I'm sure he want the money DD to him direct. He seems like a trustworthy bloke!
When do you want the money by funkymonkey?
actually no, I have a $2000 credit with em :) but yeah I'd prefer the money upfront. not really too concerned with that coz I can ebay em off if no one claims em :/ as for COD, sure no probs, COD is great... free insurance on postage ;) as long as you cover COD charges.
I'll get you guys to finalise your purchases on thursday, coz I'm tryin to sort out the VIC one right now since we all need our CB's before Saturdays cruise, if that's cool with you guys.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
