Hi all! I am a newbie here, so this is all about.
My plan to take my baby up to 300rwkw+ I am located in Sydney NSW.
Chasing an upgrade kit or some performance parts :) (mainly street use and weekend drift)
got a very healthy engine here that has done 120xxxk's and still going very hard and strong If you guys planned to get your car back to standard then swapped me and then i'd cash your way.
-ECU prefer apexi power fc with hand controller.
-high flow turbo and engine parts new or used without problem.
-injectors 550cc or higher.
-controlling system.
-whatever you got offer me! pic&price pls.
Simply my car is pretty much standard under the bonnet. will consider anything in good condition.
OFFER ME GUYS!
CHEERS!
Email: [email protected]
https://www.sau.com.au/forums/topic/384779-cash-for-r33-gtst-upgrade-kit/
OFFER ME GUYS!
CHEERS!
gday there mate , how are ya , anthony here from drift racing industries , i am based in sydney / fairfield liverpool area so thought i be able to help you out to make things a bit easier hey .
i most definately can help you out with getting your car to 300kw rw + as for a streeter / drift car on the weekends hehe
i am actually building a customers car now , well setting it up for the exact same purpose hey , love to show it to you in person
this car was completely stock standard r33 skyline auto
what we done so far too much to name lol , going from the =
1) fuel system = walbro gss 342 500hp in tank fuel pump / nismo fuel reg / 850cc power enterprise injectors that rite there is good for like 400 + kw rw the fuel setup
2) turbo side = stock cast iron manifold custom made external wastegate flange for the tial 44mm external wastegate / garrett gt3582r turbo 600 - 700 hp rating .
3) ecu computer - ems 6860 stand alone . / blitz dual solenoid electronic boost controller .
4) intake side = d.r.i forward facing greddy style intake manifold / d.r.i 600 x 300 x 76mm , 3" intercooler / custom piping to suit intake and exhaust turbo setup / metal air intake pipe for air filter pod .
5) suspension = hsd , hr series coilovers / d.r.i , front castor rods / d.r.i front inner tie rods with pillow ball ends / d.r.i rear upper camber arms / d.r.i rear upper traction rods / d.r.i rear toe control arms / d.r.i alloy subframe spacers
and etc too many parts to list man hehe
let me know wat you think man and we can set this baby up of yours and get it on the track weekend to have some fun with you mates and drift hey
thanks for your time , anthony
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
