Hey,
Had a search but couldn't find any relevant information.
I am having a few upgrades done, and installing a haltech premium ecu. This wil be running a Map sensor, so i can get rid of the AFM, but i can't find an intake pipe that includes the crancase vent return that would be long enough to eliminate the AFM. I have an atmospheric SSQV Bov, so don't need that return pipe.
The options i believe I have are,
1) Install a breather filter and have the crackcase vent straight to atmosphere and buy a universal 2.5" intake pipe
2)Have a custom stainless intake pipe made
3)Buy a silicon piping kit, block off the BOV return and extend with more silicone piping.
Any input on this would be great
Thanks
https://www.sau.com.au/forums/topic/384809-intake-piping/
you mean a pipe like this replace this bit where the afm was
i have one like that, except mine has bov return as well and are at a 45 degree angle so they are directed towards the turbo (dont know about the crank case vent but there is a thread around here some where about the bov return need to be pointing towards the turbo not on a 90 like yours) then i just use 2x3" 45 degree silicone bends trimmed to get the right angles to hook up between the 3540 and afm.
https://www.sau.com.au/forums/topic/384809-intake-piping/#findComment-6139557
The angle is only important if there is an afm
https://www.sau.com.au/forums/topic/384809-intake-piping/#findComment-6140239
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
