I think its the same as this issue:
http://www.skylinesaustralia.com/forums/topic/384722-having-issues-viewing-sau/
Might be a "SAU" problem, but I'm not getting it.
Also checked out user profile and all was good there.
I am using Windows 7 fully updated and IE and having similar problems to 8110 and elrodeo666:
1. The site often appears to use just the middle third of the screen but sometimes back to normal
2. I 99% can't access my PMs unless some one sends me a message and then I am able to reply.
3. If I hit reply button no window appears although sometimes I can use the fast reply box (as now if this works)
4. I can't edit my own posts
5. (not a ver y new problem) if I try to close links I have opened the this website closes instead
6. I tried to open a thread in this section but just got a "poll" box but couldn't even post in that
7. I downloaded "Safari" but then i couldn't even get the sign in box.
I hate to complain about the site because I appreciate what a valuable resource it is and how much time people put into it but the above are very frustrating!
regards
Bob
Hey Bob,
Love the feedback mate, seriously, its the people that say "Man, this site sucks, I do this and it breaks, get your act together!" that we dont like. But messages like yours are perfect and if I dont get messages like this, I can usually miss that there is a problem entirely.
Will check them out, thanks again!
C
Im having the exact same issues as KiwiRS4T.
Before i figured out i couldnt start threads it was just the forum being small and in the middle.
Mainly issues 1, 2, 4 and 6 as listed above.
Other than that its fine and i can get around well anough and post what i want to, just a bit annoying being all small. :)
Appreciate the effort too. I can understand how difficult it must be to run forums at times. So ill just carry on and wait till its resolved. No biggie.
Thanks!
Same issues, observed on XP SP3 with IE8 and Opera 9.26 and on fully updated Vista with IE and Opera 10.something.
1. Narrow forum forms, they MAY be wide if I press "stop loading" button before page is fully loaded, so I think forum engine applies narrowing in the late stages of loading process.
2. Cannot use full reply editor - shows no input text field. Fast reply works properly.
3. Cannot use edit button - no fast edit is shown and with full edit the above issue happens.
4. PMs are working for me. But in "viewing profile" form when I'm trying to switch between "about me", "topics", "posts" tabs, the green Loading tab appears and then a pop-up window saying "Action failed" appears.
5. Can not use sign-in form, no login and password fields are displayed.
The issue appeared in the middle of the last week I think.
A fix would be nice. Or an Advice :)
Petros.
I'm having the same issues as the ppl above. I tried to make a thread about it here yesterday but it wouldnt let me post.
Ever since a few days ago the site went to i think its the mobile version and i started having all these problems.(A more compressed layout)
I read in one of the other post to delete all the cookies but when i done that i couldnt log back in, had to refresh a dozen times.
I use google chrome.
I am having same problems in logging in from Japan. I dont have access on both home and work pc's. Extremely difficult to log in (page doesnt show section to include user name or password). I think this happened since the site was centred and narrow but it could have also started a couple of days after it the alignment went crazy.
There are actually 2 separate issues.
1. You get an 'unknown error occurred' message when you post
2. It just sits there on 'sending request' and never progresses.
Let me know if the prob sits in either of these.
when i click the add reply, reply and multiquote button (not fast reply) i dont get the input box and same with login in. Good thing i dont log out.. I've tried Chrome, Firefox and explorer. No luck with any of them. And those 2 errors you mentioned i havent experience those yet.
So, I have an update.
First of all, for those, who don't see username and password boxes, fear not, it's easily fixable, or I'd say, there is a workaround. It's pretty easy if you have IE8, and very wasy if you have Opera. I don't use other browsers, so don't know if there is an easy fix for Chrome, Firefox, etc.
Instructions for IE8
1. Start IE8, press F12, the Developer Tools window will appear. In this window click File, click Customize Internet Explorer View Source, select Notepad, close Developer Tools window.
2. Load SAU Sign In page with no input boxes.
3. Right-click and select View Source, notepad window with the current page (SAU Sign In) source code will appear.
4. Find and delete the following part
<!-- SAU_ATF_728 -->
        <script type='text/javascript'>
            GA_googleFillSlot("SAU_ATF_728");
        </script>
5. In notepad File - Save As, call the file somehow, e.g. SignIn. Make sure you assign .htm file extension to the file you're saving. Save at, say, Desktop, for convenience.
6. In IE do File - Open File (or press Ctrl+O) and select the file you just saved. Enjoy proper Login form, with all necessary Username and Password fields as well as tickboxes.   :D
In opera it's even easier - you open sign-in page, press Ctrl+U, delete the above piece of code right away and press "Apply changes". The interesting thing to notice - the line just above the script, which looks like this
<div style="width: 728px; margin-left: auto; margin-right: auto; margin-bottom: 10px;">
is responsible for "narrow" appearance of the board web forms.
The same method works if you want to bring back full editor form. Just remember - you have to get rid of that piece of code EVERY TIME you don't see input box for login or topic creation form, because every time you click on a link or a button, you basically generate a request for loading a new web page, so you will receive a web page freshly generated by server. Until the problem is solved on the hosting server, it will include that piece of code every time.
To the administrators What's with that script anyway? What does it do and why does it suppress web form generation? And what's with the "style="width: 728px;" piece right after "style="width:100%" code?
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 馃槄
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 馃珷
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
