I have noticed this since last week, for some reason I can write in this thread. When I click to "reply" or "quote" it takes me to a page where i can view other peoples posts, and I can click on emoticons and add photos, but their is no provision for actually typing anything in, no reply box comes up. When I try to click "post" it doesn't respond either.
Hope this message gets through.
Ok in this thread I can write in the "fast reply" box, but I can not quote or click the "add reply" button as it opens a window that does not let me type in a reply.
Hope this info helps.
Also can not alter profile info or use any of the functions in my profile, which I never use but I tried it out and it says "action failed".
Initially I quoted a massive piece of code, but tags inside that piece interfered with forum engine big time, so I had to remove the post altoghether. So the idea is that somebody should check their closing tags better, not all browsers automatically close open tags, and not many of those that do do so properly.
In the module
<div id="google_ads_div_SAU_ATF_728_ad_container">
The first ad insert is commented, like this
<script type="text/javascript"><!-- google_ad_client = "ca-pub-8812745528911697"; /* Internal Page Top */ google_ad_slot = "9358753284"; google_ad_width = 728; google_ad_height = 90; //--></script>
but is written properly.
The second ad inserting script
<script src="http://pagead2.googlesyndication.com/pagead/show_ads.js" type="text/javascript"> _WTF? Something's missing here!_ </div>
has no closing </SCRIPT> tag
Should be adjusted to look like
<script src="http://pagead2.googlesyndication.com/pagead/show_ads.js" type="text/javascript"></script> </div>
That basically basically fixes everything. For me anyway.
Regards
Edited by Legionnaire
  • 3 weeks later...
Just to add chaps, nothing that already hasn't been mentioned.
The problem I have is that I can't Sign In to make a post or thread at all.
I've tried Firefox, Explorer, Chrome and Opera.
When I click on the Sign In tab all that comes up is the add box and nothing else.
The only thing is can post on is my mobile phone (iPhone)
Edited by OLLIE_NZ
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
