I have noticed this since last week, for some reason I can write in this thread. When I click to "reply" or "quote" it takes me to a page where i can view other peoples posts, and I can click on emoticons and add photos, but their is no provision for actually typing anything in, no reply box comes up. When I try to click "post" it doesn't respond either.
Hope this message gets through.
Ok in this thread I can write in the "fast reply" box, but I can not quote or click the "add reply" button as it opens a window that does not let me type in a reply.
Hope this info helps.
Also can not alter profile info or use any of the functions in my profile, which I never use but I tried it out and it says "action failed".
Initially I quoted a massive piece of code, but tags inside that piece interfered with forum engine big time, so I had to remove the post altoghether. So the idea is that somebody should check their closing tags better, not all browsers automatically close open tags, and not many of those that do do so properly.
In the module
<div id="google_ads_div_SAU_ATF_728_ad_container">
The first ad insert is commented, like this
<script type="text/javascript"><!-- google_ad_client = "ca-pub-8812745528911697"; /* Internal Page Top */ google_ad_slot = "9358753284"; google_ad_width = 728; google_ad_height = 90; //--></script>
but is written properly.
The second ad inserting script
<script src="http://pagead2.googlesyndication.com/pagead/show_ads.js" type="text/javascript"> _WTF? Something's missing here!_ </div>
has no closing </SCRIPT> tag
Should be adjusted to look like
<script src="http://pagead2.googlesyndication.com/pagead/show_ads.js" type="text/javascript"></script> </div>
That basically basically fixes everything. For me anyway.
Regards
Edited by Legionnaire
  • 3 weeks later...
Just to add chaps, nothing that already hasn't been mentioned.
The problem I have is that I can't Sign In to make a post or thread at all.
I've tried Firefox, Explorer, Chrome and Opera.
When I click on the Sign In tab all that comes up is the add box and nothing else.
The only thing is can post on is my mobile phone (iPhone)
Edited by OLLIE_NZ
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
