AWSOME effort Gav.
500 RWKW! GT-RS who, what, where? :nyaanyaa:
One thing you have not mentioned is comp surge. Does it have any? Please say no!
What compression ratio is your 2.8?
:worship: :worship:
Paul
Absolutely no compressor surge. These are like the GT-RS terbs top end with the 2530 bottom end response.
The final max HP figure on E85 was at 26 to 27 psi.
I can't help wondering what the GTX2860R units would be like north of 30 psi :dry:
For the other question of comp ratio - standard HKS Step 2 kit so should be 8.7:1.
My engine has now seen 4 hard seasons of motorsport so when it's time for a rebuild it's custom pistons to 88mm in a sleeved block with a 9:1 (or higher)comp ratio.
Funny thing is, your RS's were not making this peak figure. The RS's 'felt' faster because it didn't make it's power to so much later. Haha.
It's fantastic that there is no surge!!!! When will you do a 'hero' run to show what these babies can do?
The 60 mm versions would be interesting. Come on sooner with a tad more top end over the normal 5's?
How do they sound?
I found a big difference between RS's and the 5's. Are these different again?
Hmmmm.....bit difficult to say as the induction piping and air cleaners are changed. My guess is that they are quieter. Was a bit busy trying to keep the car on the black stuff today :-)
Hey gav, can you please confirm your diff ratio and tire size? i'd like to plot your tq curve with rpm
it looks like you have about 504 ftlbs at 3800 rpm at 23psi on bp98. oh my.
Edited by black bnr32
GTS4 diffs = 4.375
265/35x18 tyres = 641mm diameter
Thanks!
It doesn't hang around does it!
Love the idle at 2.05 too
Never seen an Evo trying to be a Zebra before either haha
It is an amazing car, 2.4L, GT42 turbo, sequential dogbox, massive euro brake package, carbonfibre everything $$$$ the Zebra that is..
Edited by tricstar
    • I didnt present too many conclusions because I wanted your opinions and feedback based on your own experiences. I don't know the exact material, but it is similar to concrete and therfor only has valuable strength in compression. The forces on the set material once the head is removed would mostly be in compression since the grout wants to retain its shape and the block wants to return to its relaxed state since it's still within the elastic region. The grout would theoretically make the block more rigid. The exact amount would take a better setup on my end. Thought experiment: Instead of aliens, twist your favorite fleshlite. Now fill it with grout and allow it to sit for a week. Now try to twist it again. Observe what you see. Now get your other one and blow into it. Observe what you see. Now put it into a can and fill the space between your fleshlite and the can. After it sets blow into it. Less movement in torsion and less expansion i hope.
    • Hi. Yeah i think that DIS-008 should be ok too but i rather asked. The R8 coils are "sadly" no go for me cuz every solution is for forward plenum. The coils are too tall and one of the(4/5 DK) would not fit under stock J-pipe. And being this NA RB20 i dont even know where to get some forward plenum.(and of course i would need other stuff like custom AFM/ECU etc) and that is kinda non sense for NA without boost. I just looking for solutions for my case 🙂  I try look into those Yaris/Corolla ones.
    • Damn it, no, I topped up before I got to yours I really should look at Costco locations more when I'm out and about burning through fuel
    • Did you hit the one 5 minutes down the road from my place before heading back south? 😛
