New Garrett Gtx2860R / 2863R / 2867R
Gav
Just got my car back with the GTX2863's in my -5 housings, and it is heaps better, I have 30psi with 638hp at the wheels on E85 now, and the response and power in the mid range picked up heaps.
Can you tell me what needed to be done to the -5 housings to get the GTX cartridge to fit? I have a pair of GTRS's that would benefit from this change.
If you weren't after a big top end then the GTX2860Rs are looking the part compressor map wise . The gaps between GTX60 63 67 are not that big and its interesting the trims go something like 58 56 55 .
On paper the 60mm version looks to be a jack of all trades thought the 63mm one looks to be more GTRS/-10 territory .
Be very interesting to see how the 60mm GTX turbo goes on a standard or mildly warmed RB26 .
A .
A .
Yeah I honestly dont know what to expect from them. 400,450,500. who knows. could only base it on Gav's 63 results @ 27
Should be able to hold 30psi or whatever it takes to get them in range though.
Surging? Never heard of that with these gtx's.
In the stock -5 housings they will surge apparently.
My GTX 3076 surges loudly at part throttle, as the boost comes on. Sounds cool. :P
What was the setup?
Built cammed 2.6 33 gtr, stock airbox, stock cooler, intakes and piping, stock bov's (probably leaking boost.) twin 3 inch exhaust with split dumps (why split? The wastegates should be welded shut imo. 3 inch dumps ftw ;))
Not sure on the turbo chra, other than GTX in -5's.
surges??
mine never did, but they are a frickin animal no doubts at all
Edited by AngryRB
Looks like a Melbourne car. Yes?
Yep.
I just fitted 3/4 length Xspurt 2000's in it's rail due to the 1000's blocking with that black gunk. I also fitted a 10 micron paper element filter to trap any further crap in the fuel. It's not the first ethanol car to show these blockages, although mine has been fine.
Can you try find out whether they are 60 or 63's?
Peak torque and ~425kw on 2.6 @ 5k seems pretty impressive.
~ 600nm and 300kw @ 4500rpm..
What are your -5 and 2.8 figures piggaz?
Someone care to overlap a graph with piggaz' graph? should do a back to back for us Paul..
Wonder how much the 2.5" housing limits the performance... Either way, no bad.
These twins would be a ball tearer in the factory compressor housings with Tial rears and external gates welded off the housing, hanging underneath the turbo's. Do it Fatz. :P
Well I do have a kkk t3 twin high mount kit in my shed
Would be a nice upgrade with modern turbos attached and on a 3 litre
  • Like 1
Daz was saying this is on a Hubber. Anyone care to have a guess at what the difference is between a hub and roller dyno?
My last figures were 375 kw at 4500, 425 kw at 5000 and 470 (6500) odd up top. Boost was 27 tapering back to 25 top end.
Interestingly was the difference between setting "2" and "3" on my controller. Setting 2 is 23 PSI (give or take) and the midrange was 50 KW less than setting 3.
It would be interesting to have both cars there, get out of one and into the other.
They're 63's IIRC.
Damn stout effort. I'm too wonder if the standard compact housing is/will hamper the GTX's. Power wise it seems up there but it's the apparent surge that might be an issue.
They're 63's IIRC.
I'm fairly sure that chequered tunings dyno is setup so it's spot on with local roller dynos.
Gav made 500 on less b
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
