Just got my car back with the GTX2863's in my -5 housings, and it is heaps better, I have 30psi with 638hp at the wheels on E85 now, and the response and power in the mid range picked up heaps.
Can you tell me what needed to be done to the -5 housings to get the GTX cartridge to fit? I have a pair of GTRS's that would benefit from this change.
If you weren't after a big top end then the GTX2860Rs are looking the part compressor map wise . The gaps between GTX60 63 67 are not that big and its interesting the trims go something like 58 56 55 .
On paper the 60mm version looks to be a jack of all trades thought the 63mm one looks to be more GTRS/-10 territory .
Be very interesting to see how the 60mm GTX turbo goes on a standard or mildly warmed RB26 .
A .
A .
Yeah I honestly dont know what to expect from them. 400,450,500. who knows. could only base it on Gav's 63 results @ 27
Should be able to hold 30psi or whatever it takes to get them in range though.
Surging? Never heard of that with these gtx's.
In the stock -5 housings they will surge apparently.
My GTX 3076 surges loudly at part throttle, as the boost comes on. Sounds cool. :P
What was the setup?
Built cammed 2.6 33 gtr, stock airbox, stock cooler, intakes and piping, stock bov's (probably leaking boost.) twin 3 inch exhaust with split dumps (why split? The wastegates should be welded shut imo. 3 inch dumps ftw ;))
Not sure on the turbo chra, other than GTX in -5's.
surges??
mine never did, but they are a frickin animal no doubts at all
Edited by AngryRB
Looks like a Melbourne car. Yes?
Yep.
I just fitted 3/4 length Xspurt 2000's in it's rail due to the 1000's blocking with that black gunk. I also fitted a 10 micron paper element filter to trap any further crap in the fuel. It's not the first ethanol car to show these blockages, although mine has been fine.
Can you try find out whether they are 60 or 63's?
Peak torque and ~425kw on 2.6 @ 5k seems pretty impressive.
~ 600nm and 300kw @ 4500rpm..
What are your -5 and 2.8 figures piggaz?
Someone care to overlap a graph with piggaz' graph? should do a back to back for us Paul..
Wonder how much the 2.5" housing limits the performance... Either way, no bad.
These twins would be a ball tearer in the factory compressor housings with Tial rears and external gates welded off the housing, hanging underneath the turbo's. Do it Fatz. :P
Well I do have a kkk t3 twin high mount kit in my shed
Would be a nice upgrade with modern turbos attached and on a 3 litre
  • Like 1
Daz was saying this is on a Hubber. Anyone care to have a guess at what the difference is between a hub and roller dyno?
My last figures were 375 kw at 4500, 425 kw at 5000 and 470 (6500) odd up top. Boost was 27 tapering back to 25 top end.
Interestingly was the difference between setting "2" and "3" on my controller. Setting 2 is 23 PSI (give or take) and the midrange was 50 KW less than setting 3.
It would be interesting to have both cars there, get out of one and into the other.
They're 63's IIRC.
Damn stout effort. I'm too wonder if the standard compact housing is/will hamper the GTX's. Power wise it seems up there but it's the apparent surge that might be an issue.
They're 63's IIRC.
I'm fairly sure that chequered tunings dyno is setup so it's spot on with local roller dynos.
Gav made 500 on less b
    • They're supposed to not be compatible.
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
