Just got my car back with the GTX2863's in my -5 housings, and it is heaps better, I have 30psi with 638hp at the wheels on E85 now, and the response and power in the mid range picked up heaps.
Can you tell me what needed to be done to the -5 housings to get the GTX cartridge to fit? I have a pair of GTRS's that would benefit from this change.
If you weren't after a big top end then the GTX2860Rs are looking the part compressor map wise . The gaps between GTX60 63 67 are not that big and its interesting the trims go something like 58 56 55 .
On paper the 60mm version looks to be a jack of all trades thought the 63mm one looks to be more GTRS/-10 territory .
Be very interesting to see how the 60mm GTX turbo goes on a standard or mildly warmed RB26 .
A .
A .
Yeah I honestly dont know what to expect from them. 400,450,500. who knows. could only base it on Gav's 63 results @ 27
Should be able to hold 30psi or whatever it takes to get them in range though.
Surging? Never heard of that with these gtx's.
In the stock -5 housings they will surge apparently.
My GTX 3076 surges loudly at part throttle, as the boost comes on. Sounds cool. :P
What was the setup?
Built cammed 2.6 33 gtr, stock airbox, stock cooler, intakes and piping, stock bov's (probably leaking boost.) twin 3 inch exhaust with split dumps (why split? The wastegates should be welded shut imo. 3 inch dumps ftw ;))
Not sure on the turbo chra, other than GTX in -5's.
surges??
mine never did, but they are a frickin animal no doubts at all
Edited by AngryRB
Looks like a Melbourne car. Yes?
Yep.
I just fitted 3/4 length Xspurt 2000's in it's rail due to the 1000's blocking with that black gunk. I also fitted a 10 micron paper element filter to trap any further crap in the fuel. It's not the first ethanol car to show these blockages, although mine has been fine.
Can you try find out whether they are 60 or 63's?
Peak torque and ~425kw on 2.6 @ 5k seems pretty impressive.
~ 600nm and 300kw @ 4500rpm..
What are your -5 and 2.8 figures piggaz?
Someone care to overlap a graph with piggaz' graph? should do a back to back for us Paul..
Wonder how much the 2.5" housing limits the performance... Either way, no bad.
These twins would be a ball tearer in the factory compressor housings with Tial rears and external gates welded off the housing, hanging underneath the turbo's. Do it Fatz. :P
Well I do have a kkk t3 twin high mount kit in my shed
Would be a nice upgrade with modern turbos attached and on a 3 litre
  • Like 1
Daz was saying this is on a Hubber. Anyone care to have a guess at what the difference is between a hub and roller dyno?
My last figures were 375 kw at 4500, 425 kw at 5000 and 470 (6500) odd up top. Boost was 27 tapering back to 25 top end.
Interestingly was the difference between setting "2" and "3" on my controller. Setting 2 is 23 PSI (give or take) and the midrange was 50 KW less than setting 3.
It would be interesting to have both cars there, get out of one and into the other.
They're 63's IIRC.
Damn stout effort. I'm too wonder if the standard compact housing is/will hamper the GTX's. Power wise it seems up there but it's the apparent surge that might be an issue.
They're 63's IIRC.
I'm fairly sure that chequered tunings dyno is setup so it's spot on with local roller dynos.
Gav made 500 on less b
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
