New Garrett Gtx2860R / 2863R / 2867R
Gav
Did you use the -5 before on the non-built engine?
Or how do you come to the conclusion the GTX are laggier than the -5?
I have used HKS GT2530, GT-RS and now GTX2860 (all in their genuine housings) on a RB30 with stock cams, and the GT-RS were the only one which were REALLY laggy.
As they have been on the car inbetween I can´t really compare the 2530 to the GTX side-by-side, but my impression still is that the GTX are way better spooling etc. than the 2530...am I really that wrong?
BTW all turbos were running with about 1.5 bar / 22psi.
You are running an RB30, definitely helps with spool up there! GTX's would love the 3 litres worth of exhaust energy.
2.6 to 2.8, feels better. 2.6 to a 3.0, different ball park!
R32GTR: Used the 2860-5's on a friend's built rb26, stock stroke with 264 hks cams. Full 22psi at 4600RPM on BP 98b fuel.
R32GTR: I have personally used HKS2530's and got 22psi at 5000RPM, also on a built engine with tomei poncams type B 260's
R34GTR I have used the 2860-9 and GTX2860 at this stage.
About the boost response, keep in mind that mine still has the bigger anti surge compressor housings, these hurt my mid range boost building, because of the anti surge slots. My setup can't supply enough punch to the turbine wheels down low to spin them up quick enough to pressurise the compressor housings.
I also read up that the GTX2860 is a 400HP turbo? GTX2863 is a 430HP?
Simon has the machined -5 housings on his GTX2863's along with E85, these are the better setup for a GTX twin turbo RB26-28.
I actually found mine nicer to drive (punchier) down low with dialled in stock cams too :/
Could be down to tuning as well..
I also used the anti surge housings with the GTX, with the stock cams Full boost was there around 4500, Same as the HKS GT2530s before. HKS GT-RS with their anti surge housings did take at least another 500rpm to spool.
All on stock cams, with 100cpi cat and 3.5" exhaust.
Didnt retune since the install of HKS 256 in 264ex cams but even with 2-3 degree less ignition now feels to push a lot harder.
so in terms of response... it's better to make hybrid versions of these new turbos and potentially deal with some surge issues?
so i would use my HKS 2530's with these, like those have used their old -5's with the new GTX?
  • Like 1
I would be reluctant to go that way. HKS 2530's still fetch a price in comparison to -5, would probably be worth keeping/selling and using some cheap -5 to modify.
yeah, that would most likely be the plan.
For me though, i'd probably see if Stao could fit some VNT turbos in a low mount twin config - Vcam + variable turbos..... mmmmmmm... :D
+ stroker :D
Vnt should be easy enough to fit in that configuration you'd think! Would be crazy
ultimate for me would be...
2.8 + V-Cam (type B upgrade with greater timing advance) + Variable/VNT twin low mount + spastically high compression ratio 11:1 :D
and ultimate+ would be adding direct injection ontop of all of that...
in a billet alloy 26 block :D lol
(don't think are made anymore)
Full boost at idle
  • 3 months later...
Welcome in 2013, just realised you can have a bolt-on version of the GTX on a rb26. Which lead me to 2 choice, If I'm not mistaken, regard to bolt-on setup while still being an upgrade to -5, the gtx2860r/63 VS the RAW manifold + PTE6262 ( or wtv the number is lol, im still no pte expert).
Anyone willing to shed some light on pros/cons between these 2 setup ?
Just put the GTX 2863 cores into -5's with the machined front housing, save yourself a whole lot of stuffing around. I made 90hp in the mid range with mine and 50rpm quicker response. They ran all the way up to 33psi with 478kwatw, bloody awesome mod IMO and my car was a crazy animal at the track, they totally transformed my car IMO.
Somewhere mate, I have just sold the car a few weeks ago, I'll dig around for it, but just moved from Brissy to Perth, so I have crap everywhere.......lol.
The difference was awesome on my car, and the sound of the turbo howl at mid throttle sounded amazing, little bit like a supercharger.
can vouch for this. will put up decent chart when exhaust leak is fixed but turbo sounds like a truck spooling :P
  • Like 1
What was the rest of the setup?
My car was Aaron P's old car from Victoria which Racepace originally built, the 2.8L still but now with full E85 setup, Platinum Pro ECU 272 deg 10.1 cams, which suit the GTX 2863's pretty well.
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
