Did you use the -5 before on the non-built engine?
Or how do you come to the conclusion the GTX are laggier than the -5?
I have used HKS GT2530, GT-RS and now GTX2860 (all in their genuine housings) on a RB30 with stock cams, and the GT-RS were the only one which were REALLY laggy.
As they have been on the car inbetween I can´t really compare the 2530 to the GTX side-by-side, but my impression still is that the GTX are way better spooling etc. than the 2530...am I really that wrong?
BTW all turbos were running with about 1.5 bar / 22psi.
You are running an RB30, definitely helps with spool up there! GTX's would love the 3 litres worth of exhaust energy.
2.6 to 2.8, feels better. 2.6 to a 3.0, different ball park!
R32GTR: Used the 2860-5's on a friend's built rb26, stock stroke with 264 hks cams. Full 22psi at 4600RPM on BP 98b fuel.
R32GTR: I have personally used HKS2530's and got 22psi at 5000RPM, also on a built engine with tomei poncams type B 260's
R34GTR I have used the 2860-9 and GTX2860 at this stage.
About the boost response, keep in mind that mine still has the bigger anti surge compressor housings, these hurt my mid range boost building, because of the anti surge slots. My setup can't supply enough punch to the turbine wheels down low to spin them up quick enough to pressurise the compressor housings.
I also read up that the GTX2860 is a 400HP turbo? GTX2863 is a 430HP?
Simon has the machined -5 housings on his GTX2863's along with E85, these are the better setup for a GTX twin turbo RB26-28.
I actually found mine nicer to drive (punchier) down low with dialled in stock cams too :/
Could be down to tuning as well..
I also used the anti surge housings with the GTX, with the stock cams Full boost was there around 4500, Same as the HKS GT2530s before. HKS GT-RS with their anti surge housings did take at least another 500rpm to spool.
All on stock cams, with 100cpi cat and 3.5" exhaust.
Didnt retune since the install of HKS 256 in 264ex cams but even with 2-3 degree less ignition now feels to push a lot harder.
so in terms of response... it's better to make hybrid versions of these new turbos and potentially deal with some surge issues?
so i would use my HKS 2530's with these, like those have used their old -5's with the new GTX?
  • Like 1
I would be reluctant to go that way. HKS 2530's still fetch a price in comparison to -5, would probably be worth keeping/selling and using some cheap -5 to modify.
yeah, that would most likely be the plan.
For me though, i'd probably see if Stao could fit some VNT turbos in a low mount twin config - Vcam + variable turbos..... mmmmmmm... :D
+ stroker :D
Vnt should be easy enough to fit in that configuration you'd think! Would be crazy
ultimate for me would be...
2.8 + V-Cam (type B upgrade with greater timing advance) + Variable/VNT twin low mount + spastically high compression ratio 11:1 :D
and ultimate+ would be adding direct injection ontop of all of that...
in a billet alloy 26 block :D lol
(don't think are made anymore)
Full boost at idle
  • 3 months later...
Welcome in 2013, just realised you can have a bolt-on version of the GTX on a rb26. Which lead me to 2 choice, If I'm not mistaken, regard to bolt-on setup while still being an upgrade to -5, the gtx2860r/63 VS the RAW manifold + PTE6262 ( or wtv the number is lol, im still no pte expert).
Anyone willing to shed some light on pros/cons between these 2 setup ?
Just put the GTX 2863 cores into -5's with the machined front housing, save yourself a whole lot of stuffing around. I made 90hp in the mid range with mine and 50rpm quicker response. They ran all the way up to 33psi with 478kwatw, bloody awesome mod IMO and my car was a crazy animal at the track, they totally transformed my car IMO.
Somewhere mate, I have just sold the car a few weeks ago, I'll dig around for it, but just moved from Brissy to Perth, so I have crap everywhere.......lol.
The difference was awesome on my car, and the sound of the turbo howl at mid throttle sounded amazing, little bit like a supercharger.
can vouch for this. will put up decent chart when exhaust leak is fixed but turbo sounds like a truck spooling :P
  • Like 1
What was the rest of the setup?
My car was Aaron P's old car from Victoria which Racepace originally built, the 2.8L still but now with full E85 setup, Platinum Pro ECU 272 deg 10.1 cams, which suit the GTX 2863's pretty well.
    • 99.9% of them are viscous diffs. The 0.01% are helicals. They were only option-able in the series 2, as well. I have redline heavy shockproof in my helical. It seems... fine? I don't think anyone is ever going to know until something really breaks and at that point I'm not sure anyone will blame the oil. I just chose it because it's extremely heavy duty and my car will see not-road-legal duty for it. I've also had sadness with various diff oils in the past sweating out everywhere and/or other 'fun' things, with clutch diffs. Given you have a 1.5 way on the shelf, I'd not even bother with the diff in the car and just get to tinkering with it. I would spend the $90 on oil toward the labor of someone else putting the diff in if time poor even lol.
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
