New Garrett Gtx2860R / 2863R / 2867R
Gav
  • 5 months later...
Has anyone seen or heard of someone shoehorning a GTX 2860 into a -9 or -7 housing?  I have heard that it is possible but just haven't seen it done yet.  I think from memory you still need to use a -5 rear housing?
2 hours ago, sneakey pete said:
-5 rear is identical so it's best to use that.
Front wise -5 is to big and you'd need to use -9 from memory. Back a few pages are the gtx 2860s that I did but I used some weird stock turbo covers
Have you seen any power / dyno results from them?  I remember that you had them built but sold them on, trying to weigh up whether the extra hp over -9's is worth the $$$$
I posted this car earlier. It has since gone to a crank trigger and a few other tweaks. New engine so this is how it is for the first few hundred kms before cranking it up again.
Did this at 30psi previously. Still same GTX2863's
  • Like 2
  • 6 months later...
On 26.02.2015 at 4:01 PM, Meathead said:
I guess you could use the OEM comp hsg so sleeving is not required, In my humble opinion this would be a compromise so I just used some old HKS2530 hsgs which are T04B style (aka 5s) with an AR of 0.6
The OEM hsg. A/R is 0.42 and although from what I have read the A/R on the comp. side does not affect things too much unlike the hot side A/R which has a major affect on spool.
Using the OEM comp hsg might make it boost slighty earlier possibly hotter also. Just what I have read.
Anyway I prefer the HKS 2530/2510 gt2860r-5 housings of 0.6 A/R.
I just turned up 2 x 6061 aluminium alloy sleeves 60.00mm OD 42mm ID x 48mm long. Bored out housing to 59.94mm . heated the housing up with heat gun (measuring it to make sure its bigger than 60.00mm) , cooled the sleeves down in freezer then dropped sleeves in the housings. Once cooled machine the profile to suit . Interference fit is permanent like welding but no distortion. I put 2 scotch keys in as well although that was overkill but thats me. The important thing is the 0.06mm interference!. Best not to press it in cold either as it may gall.
Hope this helps some people out wanting to use GTX2860r CHRAs' with Skyline housings.
Keeping my fingers crossed they will be better than my 5s in every way.
thx for idea ) tuning my hks GT2510 to garrett GTX2860
Can anyone help me? is this map correct? 264cams 2.6
Edited by frakzz
  • 1 month later...
So I sold my -5's to a mate. Going on a z32 tt.
Gtx2860's are back on and setup with no boost leaks this time.
New engine and run in nicely. Still a 2.8 but nitto and crank trigger setup.
On bp 98 and 22psi goes pretty well. On e85 better again. Will get dyno tuned soon and hopefully run some more boost. She's spiking if I try to turn up gain. More work needed there.
Some custom intake pipes might get made up to replace the stock rubber ones. Running a mines front pipe with 89mm outlet, 100 cell cat and 89mm full exhaust. Not setup to dyno queen, but just haul in general :)
You missed a few steps. it's normally people saying they don't work, the poster say I'm going to make it work, everyone saying ok good luck, the poster saying it didn't work, everyone else saying we told you so
  • Haha 1
37 minutes ago, The Mafia said:
not sure what drugs you guys are on, but GTX turbos will be much better than -5s.
keen to see the results.
Every result posted has shown otherwise?
Putting GTX compressor wheels into compressor housings they weren't designed to be in, along with turbines that dont have the flow to generate the revs needed for the extra boost required for a GTX wheel to "do its thing" will be much better will it?
Be happy to be proven wrong but history will repeat itself.
  • Haha 1
Post 137. One of many examples.
J.U.N.K!
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
