  • 3 months later...
New results from a fellowzedder with gtx2863's. First graph was previous. 2nd graph are the new initial dyno results.
Snapped intake cam (twice now) so he changed out all 4 cams for stock exhaust cams (solid, no VTC anymore). New mufflers also and even bigger throttle bodies (58mm to 62mm).
[âIMG]
[âIMG]
  • 3 years later...
A bit of a zombie thread bump but I seen these turbos being shown by Spectrum Motorsports Solutions here in Canada and though they were interesting. How much of a difference will having anti surge housing make vs just standard housings
The surge slot is not there to improve performance. It is because GTX28 comp wheel will bend its shaft in solid housings, the surge slot is made preventing that problem. It looks like a T51R style sort of a insert, should make some induction noises.
Anyway, Result from an earlier highflow we did. Red line is with solid housing, and blue is with antisurge slot. From a S15, internally gated on E85 fuel
Edited by hypergear
  • Like 2
Any thoughts on the 42R compressor map they have? Seems pretty average to me but I haven't done a detailed comparison against others.
On 2/23/2022 at 3:47 AM, GTSBoy said:
Um....no? That's just twin scroll single turbo, isn't it?
BMW in classic fashion decided that TwinPower could either mean a single twin scroll turbo or two turbos. I still have yet to figure out why they bother with twin turbos on the M3 when it seems obvious to just slap a bigger single turbo on the B58 and call it an S58.
Nah, they actually use both words, in both orders, to mean two different things. One order means twin turbo, the other means twin scroll single. They is classically f**ked over by marketeers. Engineers would tell them to go f**k themselves if they had the balls and the corporate power hadn't been usurped by the business school grads.
  • Like 1
718191700_ScreenShot2022-02-25at8_08_15PM.thumb.png.1824290f6935e938355eceb520fddc50.png
From: https://www.bmwusa.com/vehicles/m-models/m3-sedan/overview.html
Because it sounds cool on paper but in reality sounds aids (literally), a M3 with an exhaust sounds horrible. Kind of a reminds me of a stock turbo R32-34 with a loud exhaust, just sounds dreadful.
The F80 even stock sounds awful even compared to an RB26. I don’t know how but BMW figured out the ideal exhaust setup to make that engine sound as terrible as possible.
  • Haha 2
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
