I milled down my PS pump on the weekend.
Going to use the stock TT pipe if it isn't a flow restriction with the new compressors also.
Bit concerned I went with the 60s now. Interesting to see how much they take on a rb30
That will be an outright response monster!!! Keen to see your results!!!!
It's been discussed somewhere. You would have to machine out the covers to accept the different wheel. Why wouldn't you just buy a set of GTX's and sell what you have?
I covered this one a couple of months back, I did some research and was told the GTX need their specific covers. Cant run the bolt on style covers (or they would just make them like that for you boys!).
Nws mate.
Are you going to give it a go either way? The info I got was that they just wont work in that housing, but I wouldn't blame you for giving it a go.
Otherwise gotta stay -5 :(
I´d kick out that stock TT pipe, even with the plate modification it´s not so ideal flowwise.
Just been on the rollers yesterday, but did not ran that good and now I´m a bit disappointed with the results.
Been on the rollers three times with HKS GT2530, last run was about 530hp and 700nm of torque at 1.35 bar.
Now (with the old tune being gone because of a computer crash) the GTX made much less, even on more boost.
Here you can have a look, the runs being done on 1.5 and about 1.7-1.8 bar.
Car popped off some hoses so I had no chance to alter A/F ratio or ignition, as it was on a dyno day and I was kind of stretching it anyways doing about 6 runs with fixing some pipe stuff/altering the boost...
For comparison (same dyno type), run on 1.35 bar dropping to 0.7 bar (boost controller safety feature not switched off) with HKS GT2530s:
And on 1.5 / 1.7-1.8 bar with GTX2860R´s:
Edited by AndyStuttgart
Nice pink bits :)
It´s my ex-GF´s car, so what should I say...
But it´s fun to smoke a lot of other fast cars with a Hello Kitty airbrushed S15 Silvia :D
...although it doesn´t really runs that well on revs as my twin GTX3076R RB28 BNR34 ;-)
As I´m not a native speaker I have to admit that I don´t really get the point what you are trying to say?
The R34 is not really tuned yet, still just running a redline of 8500rpm and not more than about 1.5 bar of boost...
He's trying to say he hopes you are revving to 11,000rpm and pushing 2.5bar to make your twin GTX3076 worth while.
why do you make reference to motors not being tuned? what tune is it running then?
It´s got an initial tune but nothing final yet...so conservative ignition timing but with adjusted fuelling of course.
I will run as much boost as necessary, same counts for the rev lmiter.
But as doing high-speed runs in Germany is a totally different story than anywhere else in the world, I will definately not beat the shit out of it for longer terms.
Because I do 300kmh+ runs for minutes it would definately kill my engine, no matter how well it´s set up. As said, totally different story than just to to some 0-200 pulls or 1/4 mile runs!
Doing that I´ll produce about 2megawatts of heat that can´t really be absorbed that well...
The GTX2860R would be the one. U'd need to make sure you get the .64 "compact 5 bolt" turbine housings to suit the GTR twin setup. The biggest problem is making good intake pipes in the tight space but if a decent amount of time is spent, it'll be well worth it.
No not yet - there are a few ways to skin the cat on this one. Given that the new GTX terbs have a 3" inlet (much larger than the 2" GT versions), I am thinking of new 3" piping from the pods to the compressor inlet.
Perth Garrett dealer tells me Garrett have 13 in stock (I assume he means Garrett Australia?). Anyway, part number is 430609-230 and retail inc GST is just shy of $400 per unit.
I ordered this part number and got turbine housings that would suit a silvia SR...It wasn't the compact rear flange mount, so $660 wasted...
I'm on the hunt again for rear housings...
Nws mate.
exactly. I had gt-ss,. bought -5 already. car beeing stored in 4 weeks no time for heavy custom works! and not sur eif the all the xtra hassle is worth the extra 50hp at this point)
The additional 50hp ain´t worth it - but 400rpm sooner RPM on a dyno and a much smoother power transition on the road are worth it.
And your drivetrain won´t be f**ked as hard...
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
