My gtx 2860s with 33 compressor housings are done... And I can't pick them up for 2 weeks. Oh well, let the suspense continue!
just as I'm about to buy 2 GTX2863 cores!!
I might wait n see how you go lol
if those 60s hit at least 420 430kw with those oe housings I'm so doing it.
Edited by mr skidz
You may have to wait a while, they shall be going onto the shed shelf at first as I'm doing a road trip to Victoria for 3 weeks straight after i get back.
But yeah as above the 60s should indeed flow a tad more than -5s.
60's would want to hit 420 rwkw considering it's not too hard to do that on bog stock -5's on E85 but without the brain damage.
brain damage?
That's carrying on a bit isn't it?
He's using a .42 compressor cover not a .60 one, we've been through this before haven't we?
Pete's obviously after better spool then dash fives and better response with Power close to a dash 5 or better.
-5's in the .42 compressor cover didn't do 420kw in a .42 comp cover!
Max boost only saw 383kw,
but you expect a lot from a GTX2860 combo that's never been done before and documented?
Let's just praise Pete for actually giving it a go regardless of the result it will spool good.
Here's the pic of the 383kw -5 in .42 compressor cover.
Mmm, 30psi by 4500rpm.
For reference, when you say custom intake piping, you mean the standard gtx anti surge covers with piping made up to suit them?
Yes thats correct. Custom inlet piping to replace the OEM setup.
Can you see a reoccurring theme here?
You put bigger wheels into smaller housings and they fail. Simple as that!
Hate to break it to you guys but billet GTX wheels aren't the magic cure for the issues that plague the stock configuration like you are dreaming up. Look at Gavin here he's ditched the factory plumbing and "HEY PRESTO" hello to some response & power! Garrett obviously put these compressor wheels into these comp covers for a reason don't you think?
But the big issue which you keep overlooking is the turbine housings. GTX wheels require higher pressure ratios to make the power over the old GT series its well documented and i have experienced it 1st hand with my own GT-GTX experience. Now how do you get your turbine to keep up with your magic billet compressor wheel???
Let me answer that for you just in case you're unsure? ;)
YOU CANT WITH THE FACTORY GTR REAR OR -5 REAR THE GTX WHEELS OUT FLOW THOSE TURBINES!!!
brain damage?
Edited by Mick_o
YOU CANT WITH THE FACTORY GTR REAR!!!
judging by your comments you don't know much.
Go back like 10 pages re read.
Edited by mr skidz
I'll do it for you.
SIMONS R34
*Std inlet pipes
*Std cooler
What SHIT were you saying again?
You should know your shit before posting garbage it misleads people that don't know better.
LMFAO!
Edited by mr skidz
Lol what does that prove? Clearly you know f**k all as there was nothing misleading in what i said so LMFAO ;)
Pauls -5 results beat that so whats ya point? As good a result as it may be its not setting the world on fire nor is it proving that the effort gone into f**king around with GTX's to bolt on is worth while. In fact it makes my point very valid because shitty old -5's still beat it!
Who said anything about winning races? You are the 1 who posted up a graph telling me i didn't know SHIT & that im posting misleading information yeah? You posted a graph of 88lb GTX turbos running 33psi of boost & then i mentioned a set of 72lb GT turbos running 28psi making more power. Can you see where im going with this?
Hate to break it to ya mate but i setup cars for a living and have been working in 1 of the most reputable shops in this land/ possibly in the world who sell parts globally and setup the worlds fastest time attack cars. So im not just some internet muppet staring at graphs making assumptions talking shit via a keyboard.
Whats your claim to fame?
well you said PAULS FIGURE BEATS SIMONS!
I was stating twice now that it's not a race so how does one lose if it's not a race?
So you work in a workshop, you must know everything?
This is why I think your not very smart and now it's on record Mick_o
How is a GTX2863 crammed in a 707160 -5 foreign housing an 88lb turbo ???
GARRETT DID NOT PROVIDE ANYONE A COMPRESSOR MAP FOR A GTX2863 IN A DASH 5 HOUSING! !
its that simple.
Sorry you don't understand, maybe I'm not famous enough for you to pay attention to me.
What if I said I hold the record for the heaviest bench press at my gym, would that be classed as a claim to faim?
Your clogging this thread up too btw.
Edited by mr skidz
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
    • Yep that's pretty much what I want to see. Racecars that look and sound like the Group A but with newer tech underneath to make them faster and safer. I'm sure there's enough VK-to-VN commodore, E30 BMWs and Foxbody mustangs shells around to make up a decent number of cars with hopefully a couple of sierras, rx7 and R31s in there too.
    • Contact Jessestreeter.com/Skevas Racing/JustJap for a new r34 rb gearbox or go a cd00# conversion. No point playing with unknown condition gearboxes.
    • Such a shame places like Amaroo Park have been redeveloped, smaller tracks always make for good racing. Cheers for sharing @PranK there's some good Lakeside video's too. Its so hard with older the cars as parts are so rare and everything was made for a particular chassis at that point in time. Even the V8 Supercar Blueprint era cars are all different between each chassis within a team as they learnt things and made improvements. The COTF cars between each Chassis builder is different too especially motor/oil systems/intakes. The Group A stuff is worth so much too especially chassis with good history. The only way to do it would be composite panels and similar engine drivelines to the original cars. Ford sierra running Focus RS driveline, Commodore running a short stroke LS/LT or a Falcon with coyote and a H Pattern dog box. Could use a standard ecu across all models with a Torque Map and DBW for parity which is not even used in Supercars currently. Hell a TCM is almost a full chassis car these days and the suspension is not even close to standard style in the front running cars.
