  • 3 months later...
New results from a fellowzedder with gtx2863's. First graph was previous. 2nd graph are the new initial dyno results.
Snapped intake cam (twice now) so he changed out all 4 cams for stock exhaust cams (solid, no VTC anymore). New mufflers also and even bigger throttle bodies (58mm to 62mm).
[âIMG]
[âIMG]
  • 3 years later...
A bit of a zombie thread bump but I seen these turbos being shown by Spectrum Motorsports Solutions here in Canada and though they were interesting. How much of a difference will having anti surge housing make vs just standard housings
The surge slot is not there to improve performance. It is because GTX28 comp wheel will bend its shaft in solid housings, the surge slot is made preventing that problem. It looks like a T51R style sort of a insert, should make some induction noises.
Anyway, Result from an earlier highflow we did. Red line is with solid housing, and blue is with antisurge slot. From a S15, internally gated on E85 fuel
Edited by hypergear
  • Like 2
Any thoughts on the 42R compressor map they have? Seems pretty average to me but I haven't done a detailed comparison against others.
On 2/23/2022 at 3:47 AM, GTSBoy said:
Um....no? That's just twin scroll single turbo, isn't it?
BMW in classic fashion decided that TwinPower could either mean a single twin scroll turbo or two turbos. I still have yet to figure out why they bother with twin turbos on the M3 when it seems obvious to just slap a bigger single turbo on the B58 and call it an S58.
Nah, they actually use both words, in both orders, to mean two different things. One order means twin turbo, the other means twin scroll single. They is classically f**ked over by marketeers. Engineers would tell them to go f**k themselves if they had the balls and the corporate power hadn't been usurped by the business school grads.
  • Like 1
718191700_ScreenShot2022-02-25at8_08_15PM.thumb.png.1824290f6935e938355eceb520fddc50.png
From: https://www.bmwusa.com/vehicles/m-models/m3-sedan/overview.html
Because it sounds cool on paper but in reality sounds aids (literally), a M3 with an exhaust sounds horrible. Kind of a reminds me of a stock turbo R32-34 with a loud exhaust, just sounds dreadful.
The F80 even stock sounds awful even compared to an RB26. I don’t know how but BMW figured out the ideal exhaust setup to make that engine sound as terrible as possible.
  • Haha 2
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
