AWSOME effort Gav.
500 RWKW! GT-RS who, what, where? :nyaanyaa:
One thing you have not mentioned is comp surge. Does it have any? Please say no!
What compression ratio is your 2.8?
:worship: :worship:
Paul
Absolutely no compressor surge. These are like the GT-RS terbs top end with the 2530 bottom end response.
The final max HP figure on E85 was at 26 to 27 psi.
I can't help wondering what the GTX2860R units would be like north of 30 psi :dry:
For the other question of comp ratio - standard HKS Step 2 kit so should be 8.7:1.
My engine has now seen 4 hard seasons of motorsport so when it's time for a rebuild it's custom pistons to 88mm in a sleeved block with a 9:1 (or higher)comp ratio.
Funny thing is, your RS's were not making this peak figure. The RS's 'felt' faster because it didn't make it's power to so much later. Haha.
It's fantastic that there is no surge!!!! When will you do a 'hero' run to show what these babies can do?
The 60 mm versions would be interesting. Come on sooner with a tad more top end over the normal 5's?
How do they sound?
I found a big difference between RS's and the 5's. Are these different again?
Hmmmm.....bit difficult to say as the induction piping and air cleaners are changed. My guess is that they are quieter. Was a bit busy trying to keep the car on the black stuff today :-)
Hey gav, can you please confirm your diff ratio and tire size? i'd like to plot your tq curve with rpm
it looks like you have about 504 ftlbs at 3800 rpm at 23psi on bp98. oh my.
Edited by black bnr32
GTS4 diffs = 4.375
265/35x18 tyres = 641mm diameter
Thanks!
It doesn't hang around does it!
Love the idle at 2.05 too
Never seen an Evo trying to be a Zebra before either haha
It is an amazing car, 2.4L, GT42 turbo, sequential dogbox, massive euro brake package, carbonfibre everything $$$$ the Zebra that is..
Edited by tricstar
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
