after installing a series 2 front bumper to my series 1.5 the indicators flash twice as fast.
I noticed the lights in the indicator are 5w t10 wedges and the old ones are the bigger 21w festoon style,
so i think the less resistance is making it blink faster
https://www.sau.com.au/forums/topic/384907-r33-indicators-flashing-too-quick/
the sensor will probably be part of the ecu. i'd try to change the resistance of the circuit before i went trying to modify an ecu. but im not sure how your gonna go about lowering the resistance. maybe a 21W wedge type bulb? if they exist? i dunno. google...
i don't think it would be in the ecu,
i spoke to a guy at an auto-one and he tried to sell me the original resistor, but obviously that wouldn't fix it.
That does mean it is just a 3 pin resistor that i need to find.
New question! If i convert all my indicators to LEDs can i just buy a resistor made for them?
turn on indicators and follow the clicking noise to the flasher unit. once you know if it has 2 or 3 terminals then go to an auto sparky or supercheap etc and get an electronic flasher unit. flasher usually looks like a small silver can
electronic ones flash at the same speed regardless of load :thumbsup:
i like that idea! id take a look into doing that
if someone tries to sell you a resistor to place in there, slap them. your new bulbs have more resistance than the old ones. putting more resistance in the line will only make things worse. if t_revs idea doesnt work i suggest making a short circuit with an appropriate resistor in parallel to the indicator circuit
http://myworld.ebay.com.au/jagtradingonline/?_trksid=p4340.l2559
Link to ebay store i used, they seem legit.
sorry mate, from my understanding it would be the same either way? so a resistor would fix it but i'd prefer to just replace the flasher unit with an electric one
seems better than mucking around with wires and resistors
What happens when you turn on the hazard lights? True the turn signal relay relies on load in the circuit turn off and on at a steady pace. Are all the turn signal lights working and are you using LED bulbs in the circuit. There is a black relay under the dash near the steering colum. Hope this is any help.
when i put the hazards on the flash normally, all the lights are working and none of them are LEDs
however i had a series 1.5 had big 21w globes and the series 2 bar has little 5w T10 wedges.
so that would be what's tricking it into blinking quick.
thanks, now i kinda know where to look
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
