attach one wire to a bolt stuck in the dirt, the other to a bolt on the car, all grounded....lol
joking
is it the D1 kit off eblow ? depends on what kit you have and available wires. ? some have a lot, some have 2 ?
https://www.sau.com.au/forums/topic/384927-ground-kit/#findComment-6141239
sounds like its missing some wires. the one I'm thinking of is this one, one wire per spark coil pack, and one new ground in addition to that.along with ground circle battery clamp. , its overkill on most cars unless youe pushing a butt load of boost, and fear misfires under extreme load. if you can post a photo of what you have I would suss you have the old kit, a bar that bolts near firewall, grounds to battery, engine, frame rail and a couple other spots
https://www.sau.com.au/forums/topic/384927-ground-kit/#findComment-6147019
Their meant to give you more power ey?
I wonder how that works....
its possible for fuel pumps to spin slower , just like a cordless drill running low charge, causing fuel rail pressure to vary and diminish (R31 used to have that problem a lot)
when voltage gets low, you loose coil spark power which could cause a misfire and blown engine if your pushing lots of boost or RPM
when voltage gets lower you loose ECU functions , it starts to do weird things.malfunctions
factory grounds (expensive copper wire ) are the cheapest they could produce and still make the car function. cost control !!
NISSAN wires are not the best, they get crusty and break , connections corrode fast as hell . update your main wires is cheap insurance so you come out and your car starts ?
https://www.sau.com.au/forums/topic/384927-ground-kit/#findComment-6147666
so in your opinion is a grounding kit worth the money?
No
you can make your own cheaper and you dont need such a big setup unless your running mad power and need every base covered , its mostly overkill on anythng but pure , pro racing , massive RPM/boost
https://www.sau.com.au/forums/topic/384927-ground-kit/#findComment-6150284
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
