Hi all,
I have a set of CP 87mm custom design pistons that are setup for use in a stroker motor. There are a lot of possabilities with these pistons. A few of these that are easy to achieve would be:
RB28 stroker:
77.7mm stroke, Rb26 Stock length 121.5mm rods, 1mm head gasket, 8.11:1cr (64cc stock head), 8.34:1cr (62cc shaved head)
Brian Crowler RB28 Stroker:
79mm stroke crank, Rb26 Stock length 121.5mm rods, 1.6mm head gasket, 8.23:1cr (64cc stock head), 8.46:1cr (62cc shaved head) (0.65mm positive deck height)
RB30 options:
RB30 cranks up to 93mm can also be supported with a stock length rod and a zero deck height. 94 would be a 0.5mm positve deck.
If you wanted to do something with offset grinding an RB30 crank and using 19mm GTiR sized journals, and 87mm stroke with a 6.125" rod would also fit nicely. I can make a crank to suit if this is something that interest you. SR20 rod journals remove about 50-75 grams of recipricating mass from each rod, and about 50 grams from the crank.
Full specs of the pistons are:
87mm bore
28mm compression height (32 is standard)
5cc RB26 Dome profile
21mm wrist pins
5.5mm crown thickness
These were a custom piston I had made for an early design of my open deck engine, but were never used due to a design change. The only time the packaging has been opend has been to photograph them.
Cost me $1500 to have made.
Will sell for $950 delivered in Australia. Also open to offers for swaps.
PM me if you need more detail.
Ph: 0434 147 478
Cheers,
Ian
https://www.sau.com.au/forums/topic/384929-rb-custom-stroker-pistons/
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
