Hey guys,
Some of you may know my car has undergone some pretty radical changes. A quick rundown of the previous setup was; GT Block, Tomei 2.8, 270 @ 10.25mm procams, Nismo AFM's, ARC Twin entry intercooler, HKS GT-RS Turbo's, HKS dumps, HKS frontpipes and a Kakimoto Full Mega N1 catback all controlled by the old faithful Power FC. That setup on E85 @ 25 PSI returned a result of 402 RWKW.
There was a few little issues with this setup. One was a fairly obvious exhaust restriction which was in the form of a 2.5 inch restrictor in the rear muffler of the catback. BAD. Another one (although there are an argument for and against with this) is the HKS split dumps. They have been replaced with Tomei Series 1's. The biggest issue was the timing jumping around above 6000 RPM like a clown on a pogo stick. I realise some workshops don't seem to have/log/know-about this issue, but we did and it got sorted. The problem here for those that may not understand, is that the timing signal to the ECU is not accurate and consistent and means the tuner can't be as aggressive or precise with the ignition maps throughout the rev range. This has a roll on effect that the car wont produce as much power reliably as it could/should. The emphasis here is on reliability over power as we all want reliable cars, which is the reason I have decided to do this thread.
Below are the logs of the timing on the standard Nissan CAS setup.
Below are the logs of the timing with the new external trigger setup.
The new setup consists of a Ross balancer and a 36 minus 2 teeth trigger wheel and pickup. This is the first FULLY completed kit to be put on a car. Ross is now selling this as a kit made for the RB26 as a bolt on part and works with a large number of ECU's (all the main ones are supported). The only thing you see on the car is a wheel behind the balancer and a pickup, but to the untrained eye you really won't notice it. The OEM CAS stays to help with starting. The car fires up first time, everytime. That's something that the Power FC couldn't match, especially if the car was cold in the middle of winter due to the E85.
The pickup and tooth wheel.
CAS is looking factory.
Changes to the car from the previous setup are; Modified Garrett -5's (exhaust housing's ported to gasket size and Racepace Motorsport modified actuator arms) , Link Plug in ECU with a 7 bar map sensor, Ethanol sensor (more on that later), Tomei Series 1 dump pipes, Nismo intercooler, Racepace twin 3 inch exhaust from dump pipes back, Ross trigger kit/Harmonic balancer. I even went back to a factory airbox after running the pods for the last 12 months. I also have a TechEdge Wideband kit that I asked Yavuz to link bank into the ECU. This enables the ECU to 'trim the mixtures' while on the freeway. A little bit of fuel economy in such a highly modified car is nice sometimes!
First thoughts going from the old to the new setup is RESPONSE! It's on all the time. In places where I would be in 2nd gear hard up it, I can use 3rd and half the throttle and it's going equally as quick. I can completely understand when "Gav" (a WA forum member with a very similar setup) said "I have a choice of 2 gear's in any corner on the track". There is also NO shuffle with these turbo's. I couldn't get away with going up any sort of incline without the GT RS's having a spaz attack. This would play havoc with the AFM's and would send my AFR's south of 10:1 (Wideband readout).
The ethanol sensor is pretty much a carbon copy of what Daniel in Victoria did to his car. Same sensor and ECU. After being on E85 for just on 12 months I got sick to death of carrying around a crazy amount of jerry cans to do an event (Thanks Steveo for being the E85 tanker for me ;) ) Some of the Vic guys can attest to this at one of their own DECA's. 11 jerry cans were taken down from Sydney to do what really is a skidpan day and had to duck into Melbourne to grab another 5, just to make sure we got home. Stupid it was!
Below is an overlay of the RS setup and he -5 setup. Pink being -5 and Green being HKS GT RS's.
More tuning will be done on the E85 tune in the very near future as we ran out of time before the SAU Nationals. The dyno graphs above were all done with the EBC OFF. Boost peaks at 24 psi and trails off to 22.5 22 psi top end. I'd like to see how far these things can go. Yavuz think's 440 450 rwkw with a little more boost and some more timing but the actual testing will be done and exact results found out soon. Yavuz isn't one to do things by half measures.
NB: I have not been paid to say any of this. I thought I would share what is a fairy big transformation in my own car with some pretty neat and new parts. It's good to see that some companies are still out there flying the RB flag for us guys and developing innovating new parts for these engines.
A big thankyou to Unigroup (Yavuz, Tyson and Mark), Ross from Ross Tuffbond for the trigger kit, Steveo for putting up with my rubbish all the time, Norm and Amy, Brett and Jack! Cheers guys!
https://www.sau.com.au/forums/topic/384932-new-rb-parts-with-results/
Seen this issue many times before wait until you add another 25mm of deck height and see how far the timing goes out about 6000rpm!!
They really need an interface that converts the signal from 36-2 to a 360 degree signal - that way the PFC guys can play too!
Fantastic results!! Great to see another Flex-fuel Skyline getting around :)
Will definitely ask Trent about his thoughts on the trigger setup too... PM price?
Would have been interesting to see the results from JUST the -5 change, see what #'s you got and THEN change the exhaust to see the difference. Or just same setup, but diff exhaust. Wonder how my Midori exhaust stacks up against the Racepace one... might have to do a little back to back at Racepace one day.
Do you know what ramp rate those runs were done at?
Well done again, it's an absolute beast and with a little more time with Yavuz, i think you're going to see some SERIOUS numbers!
Nice to finally meet you at the Nats as well :)
It will work with a PFC. It's just an extra converter box.
Steveo had the same issue with his RB30. Even Terry had this issue with his Blue V Spec II and that was just the typical "300 kw bolt on RB26"
Well don't forget the dumps were changed also. It would have been nice to do a back to back, but It was such a rush to get down to the NATS as it was!
Ramp rates. I don't know but I can find out when I am out there next.
good to see the data logging for the dodgy CAS signal compared to the new crank trigger setup
Yavuz often talked about the issues with the standard CAS and its good to see some proof of how much i can effect tuning.. not that i didnt beleive him cause he knows his Sh#t...
Just dropped my car off today and i also have one of these balancers goin on and beleive me they re NOT CHEAP!, will be well worth it in the end. Though i may have to change from a normal PFC to a Dejetro but as far as i know the balancer works for both..
.... ive always wondered why ive never heard of this issue before from other tuners?, good to see Yavuz is on the ball
Cheers for sharing Paul, good info mate
NOT CHEAP
In the scheme of things they are actually quite well priced. For all the stuff you get and the fact that it's a solid fix for the issue, it's money well spent IMO :D
Pauls one was a normal PFC and it will work on that with the 360 degree signal (although now he's a Link of course). The signal AFAIK is the same for DJetro to Normal PFC, but the converter box is slightly different then the Link one last I spoke to Ross. Leave it with Yavuz, he'll sort it out :)
Also which one is yours? The black one? We were there today
yea the black one that has a f@uk load of dust and shit on it lol... the blue 32 with the flared guards makes mine look like a dump haha
Did u manage to get a look at the turbo and manifold set up i have?... theres alot of work to be done because of how everything sits so i wont be seeing it for a while :unsure:
i pretty much only bought it because yavuz recommended it so if he thinks its worth it then he has me convinced
Hows does the power delivery feel? smoother or cant really notice it?
Yeah good point. Mine (RB30) basically got too dodgy to tune at 6000rpm, so I fitted the Autronic trigger and that kind of worked, but not too well because of how it's mounted. This one from Ross is far superior and during development as Paul and I have different ECU's the topic came up really early about it needing to be able to be used on a range of ECU's so they made the converter box that takes the signal and puts it into a 360 signal for PFC. Any ECU can be supported, thats the beauty of dealing with a company where you can talk to the boss - ring him up and have a chat and he can send you the part (or make it) to suit :D
Ahh. That one with the BW turbo on it. Nice :D Yavuz would love you as it's a big single!
I had a look, the manifold is automotive porn!
Power delivery. Well its very hard to comment as I changed to a Link G4 plug in + 7 BAR MAP sensor at the same time. But the starting (cold and warm) shits all over the PFC, it idles smoother and alot more stable. That is even with ID 2000's (2225 cc worth of injector)
Did you guys try the Ross replacement CAS at all?
Mark has one on his 2530 due to the timing going all over the place, A proper crank trigger setup is always going to be better at big revs though
Did you read my opening post Zebra? That's what the WHOLE thread is about! There are two logs there; one from the factory CAS and one from surprise surprise.... the Ross trigger!
Yes I read that, was wondering if you had tried the Ross CAS, is a direct replacement one rather than the crank trigger setup
Edit - See here
MLR has the trigger setup although he may has the Ross CAS replacement cover. I can't remember.
EDIT: Thats just a cover. I could of had that also, but Yavuz and Ross retained the factory CAS in the "Final revision" to help with starting.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
