New Rb Parts With Results
Piggaz
 Share
Joe you'll see now the kit is finished, heaps of GTR's will be getting them there. I know of one Melbourne workshop getting to play with one soon too - so it's not just Sydney siders who are lucky with this bit of gear.
From 290 to 400? Yeah, hold-the-fu(k-on, thats a big jump :D
Sorta disappointing in a way lol wouldn't have minded being one of only a few that had this kit
I spose it is like anything though.
This kit has been in the pipeline for a while now. I am not sure how long, but Yavuz mentioned it when I jumped across to E85 in Nov last year. It has been something like 3 years of Testing and tuning.
Well if it's any comfort, not everyone will be able to afford it. There's always the "close enough is good enough" crowd.
Any reason still 2.6L and not going stroker?
The day I swapped to E85 it was the same time he said the design is starting. So yeah, quite a while!! Thats why I used the Autronic one because this kit was so far off.....as you know thats another story now...
Just to back this up - I put on the Ross Trigger kit a few weeks back also. Although mine it a 12 tooth setup - I am running Motec and logged exactly the same kind of improvement. Used to get up to 500rpm jitter above 5500rpm.. now its lucky if it jitters more than 30rpm.
We also noticed immediately a better/smoother idle. And that was the only change made.
For the CAS, we just replaced the trigger wheel for one that has 1 sync slot.
Obviously doing crank triggers is nothing new, but its nice to have an off the shelf kit made rather than having to fab something up yourself.
Yea I first heard about it about a year ago as well, but ur right I don't think many people will be spending the extra cash on some thing that isn't really necessary. Especially since its a modification for more "highly tuned" cars...
I ended up buyin an engine that had already been built and I was happy with the 2.6 at that point in time ( it was a good price as well)
Though when I do eventually kill the engine "will not if" I'll be using a 2.8 minimum
Seems to be the common trend at the moment
I can completely understand when "Gav" (a WA forum member with a very similar setup) said "I have a choice of 2 gear's in any corner on the track".
...depending on which corner he is talking about.. he could mean 1st and reverse... eh Gav. ;)
(and yes, I do hope he reads this..)
Any details?
90mm Sleeved block + 3.4 crank would be interesting
somebody with more money than me should do it...
Steve you know 3.0 isnt enough right :whistling:
Na couldn't get any more info on it.. Apparently it's got a fair bit more displacement then the 34 though
Not sure how much larger u could get it lol
Edited by GTR_JOEY
That's the thing. Isn't "really necessary". Timing, combined with fuel is prob the most important things on a highly tuned car. If there is no consistancy in either of those, you really are risking that big buck bottom end.
bonus that it's a one off purchase that wont need replacement
so worst comes to worst and u wreck an engine you can just throw it on the new engine and away u go
300rwkw plus is where the the CAS problems tend to start... And there's alot more 300kw+ cars starting to get around
Any details?
Details on what?
Yer, yer, yer.......anyway to the OP - if you get to a stage where the coilpacks or sparkplugs are givving hiccups on E85 I can't say enough good things about the Billet Performance CDI kit. This really lets you get the best out of the E85 with regards to aggressive fueling and timing in the mid range.
PM me with details?
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
