Thanks for the thread. A couple questions:
-Is the ross kit available to the public in d-jetro form yet? If so, is pricing public knowledge?
-Are you able to have your tuner comment on the ross kit? I'm curious just how much more aggressive he can be with the tuning.
-Did you consider any other options for the sync issue?
When we've gone to crank trigger setups on gtr's with autronics we've found the engine can go back to being 1 degree sensitive! Without crank triggers I've seen up to +/- 6degrees timing variation on the really bad ones.
What we meant to do while it was on the dyno was to do a run on the OEM CAS and flick a switch to take the timing off the trigger and compare graphs. It will be back out there for more boost and to start using the EBC. I will come back with results.
The tuner helped design this kit. There has been alot of revision's with it.
Eww K-Sport...the other ones are ok...the ones with the twin bolt bridge. I just hate the look, but they do seem to work well. But would still rather 6 pot Alcons on 380x35mm rotors :)
Ye the D2 are 2-bolt bridge in 356mm (as you've seen on mine). The 330mm is single, as per previous link... JJR just use the same generic picture i think given D2 & K-Sport come out of the same factory. Price is $300 more.
The brake lines however are junk. So add another $100 for ADR approved lines and its $2400 :)
Junk eh? done a lot of testing yourself or are you just repeating stuff you see on the internet?
I've had no problems with the 3 kits i've bought, and I've only ever seen 1 person who had a problem with the provided brake lines.
Funny you mention that Duncan - Yes i have, given I have the on my car :rolleyes:
I also had the supplied brake lines inspected by 2 independant places who make ADR lines, both in agreeance of them being a risk. I have pics and all that will go into a review at a later date.
Topping that off two people I know have had the lines leak/split, your 1 person makes 3!
Not something you really want to occur at 200km/h, especially over a $100 part.
You make an optical sensor and trigger wheel sound a lot more complicated that it is! People have been doing crank triggers on rb's long before this kit appeared... being in kit form just makes it easier.
Edited by DCIEVE
Regardless of how simple it may appear to design and make there are always goin to be a ways to improve it....
And ur goin to want to have it 100% if ur goin to be selling it in bulk to the general public
Especially when it may be a 30 grand engine that it's being used on...
thanks for the replies...
Let's try and put this in perspective for the guys only vaguely familiar with tuning: The crank trigger mod helps the tuner push the limits of the hardware more reliably, due to the increased accuracy of the timing signal.
It will work with a PFC. It's just an extra converter box.
Steveo had the same issue with his RB30. Even Terry had this issue with his Blue V Spec II and that was just the typical "300 kw bolt on RB26"
More info on this converter box please
    • find it funny everyone claims different fuel chains, do different things with their fuel blah blah blah. We don't have that many fuel terminals in Australia. The fuel tanker trucks drive into the terminal, fill up, and drive directly to the service station and dump out. The majority of fuel you get, is coming out of the same terminals. The variation is actually at the individual service stations and how good their tanks are, as well as how much turn over they actually have. Older fuel stations, that haven't had their tanks replaced are going to end up with the worst fuel. Also a lot of older stations have shit design, and shit maintenance, and end up with more water absorption into the tank. This is when you then get a bad batch of fuel. Other shit things happen, like tanker drivers have a f**k up, and starting to unload the wrong compartment on their truck into the wrong tank.
    • This one?? In other news: I cannot tell the difference between my red MX5 with the silver grey hard top......... and the Ferrari 599XX EVO, they might as well be twins, well.......apart from the big wang hanging off the back of the Ferrari...🤔🤣, without the wing they are identical
    • Turn it into the pride flag
    • I think you'll find we're confused about what you were trying to do and how you were doing it. I would have thought that block rigidity was something you measured while loading the block in beam or in torsion, and that you would do so before and after grout filling, to see if putting material in there created a "composite" construction with the expected rigidity increase. Notwithstanding that the true function of grout is less about gross rigidity than local (ie preventing bore deflection/splitting and tying the bores to the main bearing locations a little better, etc etc). It is nearly impossible to follow your description of what you've done without closing ones eyes and making "aliens" hand shapes in front of oneself to try to follow the manipulations you've made. It's still unclear to me what you were trying to prove.
