Thanks for the thread. A couple questions:
-Is the ross kit available to the public in d-jetro form yet? If so, is pricing public knowledge?
-Are you able to have your tuner comment on the ross kit? I'm curious just how much more aggressive he can be with the tuning.
-Did you consider any other options for the sync issue?
When we've gone to crank trigger setups on gtr's with autronics we've found the engine can go back to being 1 degree sensitive! Without crank triggers I've seen up to +/- 6degrees timing variation on the really bad ones.
What we meant to do while it was on the dyno was to do a run on the OEM CAS and flick a switch to take the timing off the trigger and compare graphs. It will be back out there for more boost and to start using the EBC. I will come back with results.
The tuner helped design this kit. There has been alot of revision's with it.
Eww K-Sport...the other ones are ok...the ones with the twin bolt bridge. I just hate the look, but they do seem to work well. But would still rather 6 pot Alcons on 380x35mm rotors :)
Ye the D2 are 2-bolt bridge in 356mm (as you've seen on mine). The 330mm is single, as per previous link... JJR just use the same generic picture i think given D2 & K-Sport come out of the same factory. Price is $300 more.
The brake lines however are junk. So add another $100 for ADR approved lines and its $2400 :)
Junk eh? done a lot of testing yourself or are you just repeating stuff you see on the internet?
I've had no problems with the 3 kits i've bought, and I've only ever seen 1 person who had a problem with the provided brake lines.
Funny you mention that Duncan - Yes i have, given I have the on my car :rolleyes:
I also had the supplied brake lines inspected by 2 independant places who make ADR lines, both in agreeance of them being a risk. I have pics and all that will go into a review at a later date.
Topping that off two people I know have had the lines leak/split, your 1 person makes 3!
Not something you really want to occur at 200km/h, especially over a $100 part.
You make an optical sensor and trigger wheel sound a lot more complicated that it is! People have been doing crank triggers on rb's long before this kit appeared... being in kit form just makes it easier.
Edited by DCIEVE
Regardless of how simple it may appear to design and make there are always goin to be a ways to improve it....
And ur goin to want to have it 100% if ur goin to be selling it in bulk to the general public
Especially when it may be a 30 grand engine that it's being used on...
thanks for the replies...
Let's try and put this in perspective for the guys only vaguely familiar with tuning: The crank trigger mod helps the tuner push the limits of the hardware more reliably, due to the increased accuracy of the timing signal.
It will work with a PFC. It's just an extra converter box.
Steveo had the same issue with his RB30. Even Terry had this issue with his Blue V Spec II and that was just the typical "300 kw bolt on RB26"
More info on this converter box please
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
